Question about Pentax Optio M40 Digital Camera
The camera was dropped and was working for about 10 mins. then i went to turn it off and i noticed that the top lense was slightly bent. it now turns on then the start up pic shows, then the screen turns off. the lense will not go down. please help me.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 13, 2009
The problem is when i switch my camera on, on the
ok so I was searching for the answer for this myself.. very hard to say, because it really depends on what happened to your camera.. Did you drop it? Did it emerge in water? But for me, I have come to the conclusion for everyone who has the problem.. it is most (99%) probably a problem with the lense.. another site told me to take it to get fiixed- or to take the battery out and wait 20 min to put it back in, because this resets it. I decided to manually open the lense myself (who knows if thats bad/good to do, but a girl's gotta take her pix!!) So anyway, i opened the lense, and turned it on- the "on again off again" msg went away. So most likely, the problem does stem to the lense not being able to be opened, so the msg pops up, if you open the lense yourself your camera works fine, when you turn it off- my closes the lense-just doesnt open it. different results for different people, but i hope this helps because it was very simple.
Feb 04, 2010 | Samsung NV4 Digital Camera
My camera died with the lens out. then the next day i recharged it but it wasn't turning on. I noticed the lens was bent out so i pushed it in and it went in easily. Now when i press the power button the...
Was the camera dropped? Bent lens is not a good sign and possibly needs to be sent in for repair. If the cost is too high to replace (unless they fix them under warranty) than it's time to replace the unit unfortunately.
Nov 08, 2009 | Samsung L200 Digital Camera
I dropped my camera today. Seems like the lense
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Oct 30, 2009 | Canon PowerShot A80 Digital Camera
My neice's camera fell onto a tiled floor when the zoom lens was out and now it is bent and the camera doesn't turn on or off is this fixable?
Nope.. they are disposable.. My son worked in a camera store and that was the best "new purchase" feature, a dropped camera.
Jul 23, 2009 | Cameras
I DROPPED MY KODAK CAMERA WHILE THE CAMERA WAS ON
If you pressed it too hard in, you most likely damged some other parts in addition to the damage caused by dropping it. You need to take out the lense, inspect all the moving parts. Look for broken or bented part. The opened lense should mover up and down easily. Make sure all parts are clean and put the lense back on. Good luck!!!!!!!
Jun 09, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
The lenses are jammed
This happened to me to, try to fiddle around with the lense even if its rough try to pull the lense back out because it may be bent and stuck.
Try wobble it side to side if you notice it look a bit wonkie.
Good luck
Apr 27, 2009 | Sanyo Vpc-s1070w Digital Camera
Dropped my camera bag & my 17-55mm Lens Now will not telephoto
The best way to get it done right after you drop the lense is send it to NIKON NY . They put the lense on a resolution bench test and it make sure the resolution is great ,. This lense is very criticial and it is a must or your wasting your money . The reason is this ., The lense is a wide angle and sometimes photographers have probelms with 17-55mm lenses and sub mirror problems . So its best to be safe than sorry .
Mar 07, 2009 | Nikon 17-55mm f/2.8G ED-IF AF-S DX Zoom...
Camera lens is broken and camera won't turn on.
I had the exact same problem on a Nikon. Unfortunately, after having dealt directly with Nikon in Richmond BC, the cost of fixing it was greater than the cost of a new camera, even Nikon told me they'd recommend I just buy a new camera (and no, not selling me on other Nikon equipment, just a new camera in general). So I'd say you'll most likely have to buy a new camera. I know that's not what you wanted to hear, but its life unfortunately.  Good luck.
Dec 29, 2008 | Optimus DC-5347 Digital Camera
Why is the camera beeping?
I had t he three beep problem and also the lens was open. I tried batteries - then i noticed the lens was slightly bent - i tried straightening and it snapped and went into place. then i tried turning it on and it was fine and when i turned it off the lens closed.
Maybe your lens is bent.
Jun 28, 2008 | Samsung Digimax S730 Digital Camera
Jammed Lense)
Make sure the lense is not bent. If so, gently straighten it. This worked with mine.
Nov 28, 2007 | HP Photosmart R717 Digital Camera
Pentax Optio M40 Digital Camera Logo
122 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
