Question about Roper RAS8445KQ Top Load Washer
My Roper Washing Machine runs only in the wash cycle and will not drain and spin. What could this be and how would I fix it? yahwehagape@netzero.net
  • 180 Answers
It sounds like the lid switch.  You and usually see the lid switch without removing the casing around the rim where the lid closes.  If its not there it is under the head.  Take the screws holding the head of the machine out, pull the head foward and it will flip up over the machine.  To replace the lid switch you will have to remove the casing, or if you want the ghetto version of the fix jumper the two outside wires together.  If you do it this way, first make sure power is unplugged, second it will not stop when the the lid is lifted, even if it is in the spin cycle, so if you have kids I don't recommend doing it that way.
Posted on Nov 13, 2009
Roper washing machine fills and washes, but when it gets to the spin cycle there is no sound and it won,t spin.
Hi m3gamma1,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Washing Machines
Roper top loader problem with a RTW43408q0. Washer wouldn't spin at first. I ran that cycle again. It filled with water and didn't agitate or drain the water at all.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | Roper Washing Machines
My Roper washing machine will not drain the water after the wash cycle.
heatman101
Apr 17, 2011 | Roper Washing Machines
Spin cycle is not working . All other cycles are working.
heatman101
Oct 16, 2010 | Roper RAS8445KQ Top Load Washer
Hello my Roper washing machine is not switching
Check your lid switch. That is what controls the spin and drain cycle.
Eric
Jun 27, 2010 | Washing Machines
Spin cycle of Roper wash machine-Whirlpool won't work.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 18, 2010 | Washing Machines
Washer does not drain and spin
heatman101
May 20, 2010 | Roper RAX4232KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
114 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
