Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Alarm light flashing
Howdy guys,
I cleaned my waste pad because it says it was full. I took it out myself, cleaned and replaced the pad. Then I reset it through 'additional functions' using some instructions I located on the net. But now I just have the alarm light flashing with no message, but the printer won't print, copy or anything. Are you able to help?
    Sniper:
  • 60 Answers
1) Printer on, press Additional Functions, Scan, Copy, Scan.
Now you should be in service mode; from there to waste ink tank reset
2) Select Test Mode, which is the last available selection
3) Select #8 Printer Test, it will do some cleaning, then it will come up with an other option; this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3! Push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset, Followed by the power button and then wait for it to restart.
Posted on Jan 08, 2008
  • Iuliu Ciupe-Vaida
    Iuliu Ciupe-Vaida Jan 08, 2008
    Is this more helpfull? Is in fact the same, but kind of more algorythmic :))
    1) Enter SERVICE MODE.---
    By pressing menu-copy-scan-copy-copy
    2) Select TEST MODE.
    3) Select [8] PRINTER TEST in TEST MODE.
    4) Select 3. [EEPROM CLEAR].
    5) Select 0. [INK COUNT].
    6) Press the [Set] key.
    7) Press the [Stop/Reset] key (returning to the state of 3)), and then press
    the [ON/OFF] key.
I have a canon MP530 waste ink pad near full. what should i do?
Press the OK button.
The service call error, indicating the waste ink absorber is full,
is likely to occur soon.
Once the waste ink absorber becomes completely full, printing
cannot be done until the waste ink absorber is replaced.
To reset it:
With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT
release the buttons). The COPY button lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset
buttons. (Each time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange
and COPY in green, starting with Alarm LED.) "CANON Idle" is displayed on the LCD.
4) When the COPY button lights in green, press the Stop/Reset button the specified number of time(s) according to the function
listed in the table below. (Each time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately,
Alarm in orange and COPY in green, starting with Alarm LED.)
4 times - Waste ink counter
resetting
Hope that helps!
Aug 19, 2010 | Office Equipment & Supplies
Epson Stylus C66 PRINTER KEEPS ON FLASHING RED LIGHTS ON THE INK BUTTON AND PAPER BUTTON
Check the status monitor on the PC, this will tell you the error. If service error it need the wast ink pad counter resetting
Mar 13, 2010 | Epson Stylus R265 InkJet Photo Printer
I believe it is due to the ink overflow pads being full and now the paper light and ink light are flashing. I have a continuous flow ink system hooked up and it is stuck in the farthest right position and...
Hello!
I believe that is about a Epson ink printer, if it is, please download the "SSC Service Utility for Epson Printers" if the printer is Epson and reset the ink waste pad's. Please write the model of the printer if is not a Epson printer if the printer is Epson this should work. The software can be found on the internet for free quickly.
Regards
Jan 12, 2010 | Office Equipment & Supplies
How do I reset waste ink tank full on Smartbase mp390?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Jan 05, 2010 | Canon SmartBase MP390 All-In-One InkJet...
Says internal parts are beyond service date .
No need code to reset. just find resetter at indoreset.blogspot.com. Be sure to clean the waste pad first
Jun 03, 2009 | Epson Stylus CX1500v Printer
Waste tank is full, How do fix it, can I clean it myself?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 15, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Waste Ink Near Full
Try this:
Waste Ink Tank Reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Let me know the result.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 08, 2009 | Office Equipment & Supplies
Reset waste ink counter on Epson C60 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Feb 24, 2009 | Epson Stylus C60 InkJet Printer
Ink everywhere
You have to check if the waste pad of the printer is full. If this occurs, you have to call a technician to replace it (or yourself can do , if you are able to). With the waste pad replaced, you can reset the internal counter with this program :
This program can show you if the waste pad is full, or what problem is happening.
Apr 19, 2008 | Epson Stylus C86 InkJet Printer
Canon multipass mp390
hi i am a certified Canon repair tech for this printer. what it sounds like is that the ribbon cable that go from the carridge unit to the main board are plugged in to the wrong connector. check the connectors and try to match up by size. hope this helps.
Dec 30, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
371 people viewed this question
old marine
old marine
