I have a safe lock SP00072 safe. And I need to know how to change the combination on it. Please help.
  • 530 Answers
To reset your combination:
Press then release the red re-set button on the inside of the door.
Input 1 to 8 numbers then push the # button. The yellow light will flash on after you enter each number.
You should hear two beeps.
This will confirm the new code has been accepted.
Hope this helps.
Posted on Nov 13, 2009
Brinks gun safe problems
There are some instructions here, but generally you go as many times as you like to the left, anticlockwise and stop on your first number, then you go clockwise past your next number twice and stop on it the next time, then you go anticlockwise until you cross your last number once and stop the at your last number, turning clockwise then draws the bolt. The link at the very bottom shows it perfectly.
How to Open Your Safe by Dialing the Combination Lock - YouTube
? 4:03
https://www.youtube.com/watch?v=cEtmAtdnXz8
May 21, 2013 - Uploaded by Lacka Safe
Please enjoy this step by step instructional guide on how to dial open the combination to your safe. These ...
How to Dial Open a Combination Safe Lock - YouTube
? 2:15
https://www.youtube.com/watch?v=qEYjgOFKR1U Oct 20, 2009 - Uploaded by DeanSafe
Step by step instructions on how to dial open all group 2 mechanical combination safe lock, the easy way ...
How do I dial my 3-number combination on my combination dial ...
www.amsecusa.com/.../how-do-i-dial-my-3-number-combination-on-my-combination... My safe has a dial with straight sides or if you have a wall safe with a combination lock, the dial most likely will be flat. If your combination has 3 numbers. Start by turning the dial to the LEFT stopping when the first number comes to the 4th time on the center mark. Turn the ... To open, turn RIGHT until the dial stops. If the dial ...
Mar 01, 2018 | Computers & Internet
Manual for stramm digital electronic safe manual
The Stramm safe we have is a small one that we use to store keys for our drivers. To change the combination, open the safe with the current combination. Sorry, can't help you if you don't know that. Inside the door is a plastic panel covering the batteries. Pinch the plastic catch at the top and open the panel. There is a small red button which you can press to change the combination. When you press it, you will hear a double beep. Enter your desired new combination. The trick is that the last digit must be either an "A" or a "B" which signals the end of your combination. For example, if you want your new combination to be 123456, you can't do that. The closest you can come is 123456A or 123456B. Hope this helps. Steve, Mbeya, Tanzania
Apr 06, 2013 | Safe International Digital Electronic Safe...
Factory reset la gard 3715 electronic safe
Welcome to FixYa.
How to reset or change your lock combination:
  • 1. Enter "zero" six times.
  • 2. Enter your existing six (6) digit combination one time. (or 123456, factory default if you haven't changed the combination yet.
  • 3. Enter your NEW six (6) digit combination two times.
  • 4. If a mistake is made wait thirty (30) seconds and repeat steps 1 - 3.
  • 5. Test lock operation several times before closing the door.
CAUTION: When selecting a combination do not use birthday or other predictable data that could give correlation between the user and combination.
• Valid Combination Entry - Double signal after valid six (6) digit combination is entered.
• Invalid Combination Entry - Triple signal indicates the old combination is still valid.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 01, 2011 | Office Equipment & Supplies
Have had a CSW 3813 Sentry Safe for several years. Have had no problems until lately. Key #2090 opens the lock, we punch in combination that we have always used, then punch enter. The response is, the...
Sounds like you need a new battery replacement.
To replace the battery pack, unscrew the screw below the electronic lock case, turn the lock case to the right then remove it.
You can have the online manual from the link below, just make sure you have installed the adobe acrobat reader on your computer to view this file cause its pdf format.
http://www.sentrysafe.com/pdfs/OwnersManuals/503662.pdf
Additional info can be found from this electronic safe sentry manual
http://www.sentrysafe.com/pdfs/OwnersManuals/505748.pdf
If the problem leads to acquiring the right combination for your safe.... call the attention of Sentry Safe Shop
You must call (800) 828-1438 for combination retrievals.
or send a notarized letter stating you are the owner of the safe, personal information, model and serial number of your safe and must indicate the method on how you will receive the combination.
See further details from this link
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Please post back for any clarifications and let me know so I can help you further.
Apr 05, 2011 | Sentry Fireproof Safe
I HAVE A HONEYWELL 2087D SAFE I CHANGED THE COM AND CANT REMEMBER WHAT I CHANGED IT TO. i CANT FIND THE MANUAL AND NEED TO FIND OUT HOW TO OPEN IT...
Hi I have the key and know the code , I want to change the code on my Honeywell 2087D I have lost the book what's the trick? I have no red reset button. Please HELP!!!! Sharon
Dec 01, 2010 | Honeywell Safes 2087 Waterproof Fire Safe...
How to creeate a new combination for a sentry 1310 valueguard saf
Have a 1310 Sentry Valueguard safe and cannot remember the combination nor can i remember where i put the paper that i once wrote the combination down on....need help!
Aug 01, 2010 | Sentry FIRE-SAFE Combination Safe DS3431,...
I need the manual for an ADG Sportsafe. I changed the batteries and the combination I had was lost. The safe is in the default combination. I wish to see the manual to know how to cahnge the combination.
Click on the link below to go to the site with your instructions. Once there, find your model in the list of blue links and click.
http://www.adgsports.com/productinstructions.php
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE ME
Nov 24, 2009 | Locks & Locksmithing
Locked out of my cs2 safe
If you registered your safe with the manufacturer they will normally let you know your combination if you have registered the safe.
If not you will need the serial number on the side of the safe and you will need a notary stamped paper explaining you are the rightful owner of the safe.
Costs will apply to the Notary and possibly from the manufacturer.
Aug 23, 2009 | Safe International Digital Electronic Safe...
Century safe lock , not able to open the combination lock oper b
just boughy it and instructions got thrown away by accident . I have keys but no combination please advise..... Numbers on door that are tagged on is: BJ-285913* an another sticker that says 50310 BJ285913 please advise...
Apr 28, 2009 | Safe International Digital Electronic Safe...
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
