Question about LG Neon GT365 Cell Phone
My ringer does not work. I cant hear any sound whatsoever,it only vibrates. I checked all the settings and it should ring. Even when i try to listen to my ringtones it will not make any sound.
Blu Advance 5.0 ringer sounds won't work.
Hi if u have silent mode turned on u won't hear a sample ring tone check where u adjust volumes there should b a silent mode on or off..Cheers..
Dec 20, 2016 | Blu Cell Phones
Pebble ringer inop
Does it have a speakerphone function, does that work? It would seem that the second speaker is malfunctioning. There is usually seperate speakers for the earpeice and for the rigner/speakerphone. You could open the phone and make sure the speaker is sitting correctly, it could have rotated off it's contacts. But you may have to replace the speaker, possible found on eBay.
Mar 20, 2008 | Motorola Mobility PEBL U6 Cellular Phone
I have got Nokia E63....my phone is not ringing... every time when i got incoming calls or messages...it just vibrates..even i can't listen to music by my music player..there is no problem in my...
It seems the speaker or buzzer is already busted and need replacement.sometimes it happens when the phone drop on the ground or been playing sounds fully loud for a long time.parts is available in any mobile service shop near you.
Jul 11, 2011 | Nokia E63 Cell Phone
Hi! i just bought a lg-ks360 and i don't know what to do! i just can't hear the phone ring when i get a call or a text message. i tried using the alarm clock and it was useless, i just didn't hear it ring!...
You may just have the phone's ringer at a very low volume or on vibrate. Just raise the ringer volume and you'll be able to hear everything. If you're listening to a mp3, pause it and try to raise the ringer volume.
Apr 30, 2011 | Cell Phones
My phone will not vibrate at all anymore
Hi
Make sure your ringer is not in vibrate mode. Try These this thing first
Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls.
Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.)
Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option.
Press OK to assign a ringer. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not. Make sure the increase the volume using keys on side of your phone.
If none of these works the ******** motor needs to be cheked for loose connections inside the phone.
Thanks for using Fixya
Mar 24, 2011 | LG Ally Cell Phone
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
I can't hear any sound.And instead of ringing it vibrate.Even I've try to listen song but nothing is happening.
Hi there
First go to your ringer settings to check if the volume is not too low or turned off.
The problem is from your RINGER/SPEAKER,
The ringer/speaker is what brings out sound from your mobile phone when you are called,you receive a text message or you are playing music.
The ringer of your phone is faulty and you need to get a repairer to replace it for you to solve this problem
Thank you for visiting fixya
Feb 25, 2010 | Sony Ericsson K800i Cellular Phone
I have just been given a RAZR phone as my old phone didnt like going for a swim. I have set the ring tone and I can hear it. the volume is set as high as it will go and I can hear the sound as I adjust it....
The problem you are experiencing is that your ringer/speaker is faulty,
The ringer/speaker is what sounds out when your phone is called or you receive a text message
The only solution is to have it changed
Problem solved!!
Feb 23, 2010 | Orange MOTO RAZR V3x GSM Mobile Phone...
Ringer....
SOUNDS LIKE YOUR SPEACKER GHAS GONE AND ITS CHEEPER TO BUY A NEW PHONE THAN TO GET IT REPAIRED
Apr 11, 2007 | Motorola Mobility RAZR V3
Sound problem
dear replace the speaker of ur phone in k300 the speaker and ringer are the same if u not have new speaker then short both point of the speaker to gather will be ok.
Mar 18, 2007 | Sony Ericsson K300
LG Neon GT365  Cell Phone Logo
338 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
