Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
I HAVE A POULAN CHAIN SAW MODEL P4018 WILD THING. THE CARB HAS 2 BRASS PLATES. THE ONE FOR THE CHOKE IS IN BUT THERE IS NONE IN THE TOP . iT HAS THE ROD BUT NO PLATE OR SCREW TO ATTACH IT. WOULD THIS KEEP IT FROM STARTING?
  • sousa_bandit Nov 14, 2009
    I did not rebuild the carb for it has never been used. I have since then removed the carb and there is 1 round brass disc in the bottom for the choke but none in the upper which leads to the valves or piston.
  • dontbother10
    dontbother10 May 11, 2010
    You don't say so but did you rebuild the carb or disconnect it for some reason? I think setting the choke on your saw also sets the fast idle, and yes trying to start it without the throttle advanced is difficult to impossible.
  • 486 Answers
That should be the throttle plate. If it came loose, it may/should be laying in the intake manifold or it may be on top of the piston. You need to find the parts before trying to start. A small screw that fastens the plate, when it becomes lougged in the top of the piston can destroy the cylinder.
Posted on Nov 13, 2009
Poulan chain saw wild thing will not start
simple things first
right fuel /oil ratio in tank ?
aircleaner not blocked off with sawdust?
stop switch set to correct "run" position , switch not broken damaged ? chain brake set ?
choke set correct to start ?
primer bulb working correctly , fuel is visible inside bulb
Apr 30, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro Wild Thing will only run with choke out. Carb has been fully rebuilt and new lines added. As soon as throttle is pulled and choke pops off, engine dies. Any recommendations/suggestions? Thanks,...
If not already done replace the fuel filter in the tank, it is obviously fuel starvation, if no better increase the the fuel mixture on the H and L screws ( turn anti clockwise 1/4 turn on each to start with)
Feb 27, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chainsaw high revs, floods, and dies when i let off the choke
its been standing all summer ,,,yes? you have a carb fault strip the carb and fit a new repair kit in it,
also clean out all the carb jets,,plus the tank filter
Dec 02, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My poulan wild thing will start but will not stay running without holding the throttle. What should I do?
Get some sta-bil fuel stabilizer. add twice the amount recommended on the bottle for storage to your mixed gas. Empty out chainsaw tank and refill with the new mix. Rub for 2 minutes, then shut off. Remove cover over carb and spray inside carb, soaking it down good and cleaning all internal surfaces visible - allow to sit overnight.
Next day
Spray down carb with carb cleaner for about 15 seconds. Start saw, allowing 2 minutes to warm up and reduce choke. If saw stalls, restart and spray inside carb as it runs with choke on - keep motor at the highest rpms you can as you spray - spray in 2 second bursts, not allowing motor to stall from spray. If it stalls, change sparkplug and try again. You have varnish build up in the carb and are trying to remove it so the carb will work without the choke. This may take some time but it is the exact procedure I used for my Poulan Team Realtree last spring - I spent about an hour spraying and staring before it ran without the choke.
Good luck!!
Nov 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 18" Gas chain saw starts no problem but it runs for maybe 30 sec. then stops each time. I changed the core same thing.
Do a tune up. It is easy. Just take out the carb and clean with any commercial carb cleaner nad change the spark plug.
Oct 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Oil mixture wild thing
The oil mixture is 50-1 or 2.8 ounces per gallon of gas...
heatman101
Sep 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Doesnt stay idling
on the side of the fule pump/ carb there is two brass screws one is for top steed one is for tick over tweek first one if no luck tweek the other, ps on do them first half a turn only
Oct 25, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Adjust high low screws on carb.
I just finished looking at mine and I think they made it that way so back yard mechanics dont tinker with it. If there is a Poulan dealership in yout area that would be the place to get it.
Mar 27, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan chain saw after carb rebuild.
Is thereadjustment somewhere on the saw
I think there is 2 .
Feb 03, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Nov 13, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
229 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
