Network the is a lan network use windows xp . total 19 pc and internet conection sher all pc .but some time one pc is not availabil interrnet .when i do disabel and enabil Local Area Connection then net availabil what is the problem
  • networkmagic May 11, 2010
    Are all of the PC's connected to one network switch, or is the network made up of more than one switch? What brand and model is the switch that connects to the troublesome PC?
  • 407 Answers
Hii you conect net server pc . all pc conect in switch ..then your name all pc diffence .. and net conect server pc then go net conection dailbox properties ..networking ....enabil network conection then so server pc auto ip address....apply ok  done
Posted on Jan 28, 2008
How can i install wireless lan conection
You go to networks on control panel.
You must have
A) a Wireless router to connected to the INTERNET
B) an account with an ISP.
Before you can set up your computer for wireless,
Mar 07, 2010 | Microsoft Windows XP Professional With...
I have labtob using win98 without lan port to conect to network use usb lan but not work with win98
Windows doesn't support plug and play until Windows Me. Upgrade to Windows XP. Be sure your computer has the minimum requirements for Windows XP before changing the opperating system.
Apr 17, 2009 | Network Computing Devices Computers &...
How can i connect to the internet using my switch??
Basically Internet connection required a networking connection for multiple number of PCs.There are 5 types of network connection and most simple and common network connection is Local Area Connection.You can use Windows Xp or Vista for your OS, when connection was made set up your lan from your internet server from cd provided by DSLinternet server.You should Have one PC server for your multiple PC as the administrator.If your inernet was configured from your PC server(as administrator) Share your internet using your LAN in each PC using Windows xp follow set up networking clicking additional task and click Home and office networking then follow wisard set up.You Have now internet connection in your multiple PC.
Feb 24, 2009 | Computers & Internet
How to share internet connection on Windows Vista OS. I want to share internet connection between two Laptops using Windows Vista Operating system and the other using Windows XP. The Host computer is...
All right let's call your Vista computer A and your Xp computer B. First you have to bring the two computers into LAN. If you already did this, please skip the next eight steps.
Step 1: In Vista, before doing this you should enable Sharing and Discovery. You can do that by going to Control Panel -> Network and Sharing Center. Under the section ‘Sharing and Discovery, enable Network discovery, File Sharing, Public folder sharing and others if you want to. (See picture below)
Step 2: If your LAN card that is connecting to another computer is installed, it will be shown under Control Panel -> Network Connections.
Step 3: Right click that local area connection and click properties.
Step 4: Under the tab ‘Networking’, click the properties Internet Protocol Version 4 (TCP/IPv4).
Step 5: Click the radio button to ‘Use the following IP’ and give an IP address (For example, IP address: 192.168.0.1 and Subnet Mask: 255.255.255.0)
Step 6: Don’t give any other information, Click Ok and close everything.
Step 7: In computer B, which is the XP, make sure you enable the LAN card which is used to connect to computer ‘A’. Here you need not give any IP information as Computer ‘A’ will assign an IP address dynamically. If it’s not working make sure there are no IP assigned and change the properties to ‘Obtain an IP address automatically’.
Step 8: Test the connection by pinging. (You can do this by typing ping 192.168.0.1 or whichever is Compter ‘A’s IP in the comand prompt)
NOW your computers are connected. Now to share the internet:
Right click LAN card which is connected to Internet under Control Panel -> Network Connections and click ‘Sharing’ tab and enable both the options to share Internet. (Note: Unless there is another enabled LAN setting you will not be able to see the shared tab under properties)
Click Ok and close. This option is given by the Windows OS known as ICS (Internet Connection Sharing).
Now you can use Internet from both Computer A and Computer B from a single connection.
So this is the setup you need on the Host computer as you requested, if you turn out to need help witht he XP one too, let me know:)
Feb 14, 2009 | Compaq Presario 700 470024-192 Notebook
Download of new XP windows stuck in 16 bit resolution screen
sorry, but learn how to install xp pro. Skip the internet connection. Plug the plug. Install internet AFTER the xp install. let it ride
Jan 25, 2009 | Intel Motherboard
LAN not conecting
remove ur lan card and clean it and install it
Jan 21, 2009 | Acer 91.AB370.001 Network Adapter
Lan internet
the easiest way to setup internet on the laptop, is to go to control panel, and launch the network setup wizard. this will enable you to setup a new network, and scan for a local area network connection. this will also give you access to the troubleshooter. to solve any connection problems or issues, should there be any. If your using a wireless method. Your PC must also be able to transmit/receive wireless Signals. If hardwired you,ll have to use the network setup wizard, as this will auto determine I.P And any other DNS settings et,c.
Hope this Helps Mike @ compurepair.
Jan 14, 2009 | Toshiba Satellite Pro L300 Notebook
Wireless internet not working contacted perlico and they said that lan port was not open
try pressing start, control panel, network and internet conections, network conections this should show your lan page then press on the lan you need to conect then it should be conect or bridge conections
Nov 04, 2008 | Siemens Computers & Internet
How to share lan 3 pc internet
What network interface do you use? Kindly specify what networking hardware did you have there?
Feb 27, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
754 people viewed this question
David Payne
David Payne
