Question about Kenmore 24032\24036 Top Load Washer
Hi , my washing machine recently started not spinnig as good as it use to. The clothes are still soaked. I heard it could be the coupler, but turned it upsidedown and looke at it myself and it looked fine. Any Ideas on what the problem could be?.
  • warrensyards Nov 17, 2009
    I spoke with a tech and said usually the coupler is designed to go before the trani, and there was no leaking fluids under or around the washer, help!
  • 180 Answers
Probably your transmission starting to go out.  Check to see is there is a ring of oil around your casing, or oil leaking out under the machine.  If there is replace the transmission.  Check to see how easy it is to rotate the basket.  Sometimes things get stuck between the tub and the basket.
Posted on Nov 13, 2009
I want to keep the water in my Roper top load washer overnight so it will soak the load of whites I have started but the machine drains.
You should be able to select a soak cycle without having to turn off the water supply, but it may time out eventually and drain the tub. This p[events oversoaking the clothes
Oct 13, 2012 | Roper RAS8445KQ Top Load Washer
Wont spin on the cycle cloths come out soaked
Broken drive coupler
What you have is a broken drive coupler HOW TO VIDEOS
Oct 21, 2011 | Kenmore Washing Machines
Hi machine wash overloaded with clothes and then I smelled like something burning. It is fuling but not starting could you help me please.
The burning could have been the motor or the coupler. The coupler is designed to break so permanent damage to the motor and parts does not occur.
Jan 28, 2011 | Admiral 32 cu. ft. Washer
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
My clothes are soak and wet after the spinning cycle ends
Could be a gearcase problem or a motor coupler problem or a clutch problem .Best off to call a reputable service company such as Sears.
Feb 06, 2010 | Washing Machines
Hi. My washer suddenly stopped running the high speed spin. The drum will roll for the cycle and rinse but it will not spin at the end so the clothes are coming out soaking wet. Any suggestions? ...
HI there,
Well first of all you can check the motor coupler-
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning then you may have a broken coupler. many washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it. Please post comments for more help or information.......
Good Luck!!
Thanks
Jan 24, 2010 | Frigidaire FTF2140E King-Size ENERGY STAR
Kenmore 70 series washer, clothes are soaking wet after spinning
If it fill and motor runs but will not agitate it likely is the coupler. If you have the cabinet off and see the motor here is what you do.
there are 2 metal straps that attach the motor to the transmission. take the screws out that hold the straps on and pop the straps out of their slots. the motor will then come off and the coupler is between the motor and transmission. One section goes on motor shaft and one on the transmission shaft with rubber bushing in between.
Coupler part number is 285753A
May 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Spin mode does not work
Dear "FixYa,"
I have fixed the problem with my washer.
I started clothes washing machine with one load of clothes.
Wash and rinse process completed, as it came to spin,
Machine stop, only I heard was running motor. I opened
machine and found coupler is cracked (broken) and was
unable to rotate the gear.
I replaced new coupler and machine started to work normal.
Thank you
Kanu
Apr 18, 2009 | Whirlpool Washing Machines
TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Jan 28, 2008 | LG WM-1832C Front Load Washer
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
145 people viewed this question
fordexpert
Mike Squire
Robert Rankin
