How to returned the sound and audio device on my computer?
    President:
  • 1,865 Answers
You have to reinstall the sound card driver
Posted on Nov 13, 2009
No audio device is showing on my gigabyte 7vm400m-rv motherboard. what pin connections should there be to enable this function
Hi Steve
You don't say which Operating System you use, so my answer will be presented in general, Windows terms. If yours is a non-Windows Operating System and my answer seems to be of some relevance to you, please consider applying the logic and principles involved here to your own Operating System and, if in doubt, please feel free to add a Comment or Clarification to this Question. Please include information about the type, model and specification of your computer, its Audio/Sound Card and its Operating System. Doing so helps us makes faster, more accurate and more assured Remote Diagnostics leading to better quality and more useful Advice, Answers, Guidelines , How-Tos and Solutions.
You also don't say if you are using the on-board sound or a separate, dedicated PCI Audio/Sound Card.
Pin connections on the motherboard relate to the Front Panel Audio Connectors on the front of your Computer only.
If no audio device is showing on your Operating System's desktop, then this is an Audio Driver or Audio Device Settings problem, rather than a motherboard Front Audio Panel Header Pin Settings issue.
Start > (My) Computer > (System Properties) View System Settings > Device Manager
This will tell you if the Audio/Sound Device is installed and functioning properly and if the Audio/Sound Driver is installed properly. If a yellow question or exclamation mark appears next to the Audio/Sound Device, then there is a settings anomaly, fault, error or conflict with the device and/or its Driver.
AUDIO DEVICE SETTINGS
For your Audio/Sound Device to function properly, it must be set as the Default Device:
Start > Control Panel > (Hardware and Sound) Sounds and Audio Devices > (Manage Audio Devices) Audio > click on the preferred Default Playback device > Apply > OK > restart computer.
AUDIO/SOUND DRIVER PROBLEMS
Re-install the correct Audio/Sound Driver that relates to BOTH the device and your Operating System, then restart the computer. Install the Audio/Sound Driver either from the motherboard's Drivers and utilities CD or from here:
http://www.gigabyte.com/products/product-page.aspx?pid=2323#dl
Please note that this motherboard supports only Win 95/Win 98/Win 98SE/Win ME/Win 2000/Win NT/Win Server 2003 (32 Bit)/Win Server 2003 (64 Bit)/Win XP (32 Bit)/Win XP (64 Bit) and possibly also some Linux Distros (Operating Systems). If your Operating System is not included in this list, then it is highly probable that no Audio/Sound Drivers exist for that Operating System.
If this is the case, then consider buying and installing an inexpensive, basic 5.1 or 7.1 PCI Sound Card that is pre-confirmed as being compatible with your Operating System.
For motherboard pin settings diagrams, download the manual for this motherboard from here:
http://www.retrevo.com/support/Gigabyte-GA-K8VT800-manual/id/23286ag203/t/2/
MOTHERBOARD FRONT PANEL AUDIO HEADER SETTINGS
Pin 1 Left is usually MIC IN
Pin 2 Left is usually MIC BIAS/MIC PWR/MIC 5V
Pin 3 Left is usually OUT RIGHT
Pin 4 Left is usually GROUND/GRD
Pin 5 Left is usually OUT LEFT
Pin 1 Right is usually MIC GROUND/GRD
Pin 2 Right is usually Empty/Blank
Pin 3 Right is usually RIGHT RETURN
Pin 4 Right is usually Empty/Blank
Pin 5 Right is usually LEFT RETURN
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 15, 2011 | Gigabyte GA-K8VT800 Motherboard
My speakers where runnin and immediatelty there is no power supplied to the speakers which in return not working now wat ll i do...?? is it a problem wid adapter or wat..??
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 21, 2011 | Creative Labs Audio Players & Recorders
We hooked them up to a Dell computer, but there is no sound. We checked the audio drivers and they are all working properly. What can be the problem and possible solution?
You can try to plug in an external headphone to see if the issue is with your sound card, if external headphone works, obviously the speaker is faulty but if same problem persist. Check if your using an expansion sound card (usually for gaming computers) and make sure it was set primary sound device on BIOS and the integrated Audio is disabled. On windows you can check the sound settings on playback make sure that primary Audio Device is Set to default and no Hdmi Sound Audio is connected Hope this can help you!
Dec 07, 2010 | Dell A215 Computer Speakers
How can I return the audio of my PC? I reformat it and after the reformatting it's audio and soud disappear.
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 04, 2010 | Computers & Internet
We can not find sound device in this computer, we want to install sound can you help us
Yes we can help you.
To locate if there are sound device in your computer.
1. Go in control Pannel
2. Double click sound and audio device.
3.Click on the audio TAB and you will find the default audio device.
If there are no audio device, you wiil see the same in fade mode.
that there are no audio device present on the machine.
Physically you will need to check on the computer if there are sound card.
Sometimes audio device are present and are disable in the bios.
11bd5df.jpegI
IF NO SOUND DEVICE ARE PRESENT YOU WILL NEED TO BUY SOUND CARD THAT CAN BE PUT IN PCI SLOT IN THE COMPUTER.
Also there are usb sound card device more easily and praticall to buy and intall and to use.
We hope you got and idea of sound device.
If you need any further help or suggestion do not hesitate to revert back.
Thanks
Regards
uttam
Jun 08, 2010 | Computers & Internet
Hp pavilion dv9000 no audio device - change from vista to xp
Here's the driver you need to install:ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34204.exe
Jun 07, 2009 | HP Pavilion dv9000t PC Notebook
Need to get audio device back into computer
First you should check to see if the audio card is in the Device Manager. If not, try shutting down, unplugging power to PC open case (only if your comfortable doing so), physically remove the sound card and re-fasten it in the respective slot. Reconnect power and go into the BIOS. Once in the BIOS, get to the section of integrated peripherals, and disable the on-board audio. Save and exit, then let it boot up. If you get no "Found New Hardware", open the device manager and see if the card appears in the list. At this time if there is a question mark or an exclamation point, you have either a hardware conflict or an unknown device. If you don't have either of the symbols next to the audio card in the list, try opening your audio properties again and see if the card has returned to the software. If the device is not there, but is on the list in Device Manager, try re-installing the software it came with. If you have the other issues with the symbols and re-installing does not work, there may be something more than what may be the obvious.
Mar 11, 2009 | Computers & Internet
NO AUDIO OUTPUT DEVICE IS INSTALLED
windows key + R = open : devmgmt.msc
Sounds, video and game controlers > (right click) Realtek high definition audio > update driver sofware > browse my computer for driver software > let me pick from a list...> double click on Realtek high definition audio > YES to update driver warning > AND SWEET SOUND IS AUDIBLE :D
Dec 14, 2007 | Microsoft Windows Vista Ultimate Edition
Sound on my speakers
Check that the PCI card has not worked loose on the motherboard.
Oct 06, 2007 | AOpen AW 850 Sound Card
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
