Question about General Electric 20amp 2-pole GFI circuit breaker
20amp breaker tripped unexpectly tonight. tried resetting at panel but won't click all the way over and little red indicator also on the breaker
  • mikeb103 May 11, 2010
    What does it control? Also, are you turning it all the way to the "off" position before turning back to the "on" position?
    President:
  • 704 Answers
Hello, In order to reset circuit breakers that have tripped under load, you must first flip the breaker all the way OFF, before you can then turn the breaker back ON. This should reset the breaker to turn the power back on to the circuit supplied by this breaker.
The red indicator is just there to make it easier to find the tripped breaker. Typically, the red indicator flag is a special feature of Square D QD breakers and panels.
If the breaker immediately trips again and doesn't stay on, then the device it is providing power to, still has a fault and it needs to be looked at to determine what is causing the fault and the tripping of the breaker.
Be sure to turn the breaker OFF if you are going to check the device for potential problems.
I hope you find this Very Helpful and best regards!
Posted on Nov 13, 2009
We want to buy a Neff bu-in double oven which needs a 20 amp supply (hard-wired).Our old existing oven is running on a 30 amp supply apparently. Will we have problems when the new Neff is fitted?
The breaker could be changed from 30a to 20a. A 30amp breaker will run the unit but you will have less/no protection since the oven will pull 10 extra amps before it trips which could totally fry your oven depending on the failure.
Re-check the wording to see if it says 'minimum' 20amp breaker or if it indicates 20amp breaker only. If it's minimum 20amp I'd run it.
If it says 20amp only, I'd change the breaker. The existing wiring and outlet will be OK, if the plug-in is the same.
Get an electrician to change the breaker. You should really know what you are doing before you try it yourself.
Sep 16, 2017 | Neff Ovens
Federal pacific breaker that has not tripped but no power in circuit.
I have run into 2 over the years that had "GLAZED" contacts. Will read voltage good but no amperage to run anything. Try replaceing it.
Dec 13, 2013 | Federal Industries Federal Pacific 20Amp...
MY JETS WONT TURN ON
The threaded knob should not be related to the problem, it just controls how much air gets mixed into the water jets. One possibility is that the electricity is off. These tubs should receive power through a Ground Fault Circuit Interrupter (GFCI) type of circuit breaker for your protection from electrical shock. Check your circuit breaker panel(s) for a breaker with a little square white or yellow "test" button. Refer to the label (if it is there) to see if it refers to "tub" or "spa" or "bath" or something like that. You may have to turn the breaker handle off (push extra hard to make it reset) and then back on again. If the breaker handle is in the "on" position and the "test" button does not "trip it off," call an electrician. If no luck there, check the bathroom for an electrical outlet with GFCI protection, again looking for white or yellow (or red) buttons - one should be engraved "test" and the other "reset" as the electrician (I hope it was an electrician) may have supplied the tub from this outlet (not actually up to code). Plug an appliance or light into the outlet. If it doesn't work, push the reset button on the outlet and test again. If working, now test the spa. If that doesn't work, test every other GFCI outlet you can find - in the kitchen, other baths, garage, outdoors, basement, etc. using the same testing procedure. If you find a GFCI breaker or outlet "tripped" that restores the tub, that indicates there is something wrong with your electrical system that could cause you to get electrocuted, and requires that you hire a qualified electrician to investigate the problem. The same is true for any GFCI outlet that does not "trip" and/or "reset." If this doesn't fix the tub, the problem may not be electrical but some other problem with the system, indicating a plumber or spa tech may need to be consulted. Note: these GFCI breakers and outlets are supposed to be tested and reset once every month. How many of us do that? Well, at least as often as we test our smoke detectors, I suppose.
May 20, 2013 | Home
Have a carrier 92 furnace. electric motor will not kick on...just hums. red light on circuit board flashes...help?
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
However you can have a missing 1 phase , test with the VOM, for to measure voltage. Or motor need repair for winding trouble,bearing.If you do not have enough experience call some electrician.
God bless you
Oct 08, 2012 | Heating & Cooling
The red 20amp braker at the bottom of my box keep berking with only a small amont of things pluged in. Any part of the house THE SAME BRAKER brakes . is that right? The same braker?
sounds to me that the breaker is getting weak,try replacing breaker with new one,if it still trips then you have electrical problem in a circuit.
Dec 20, 2010 | Sylvania Circuit Breaker - Zinsco/ RC 20...
What does the ambere (yellow) light on the breaker mean when you turn it on or it trips out and you reset it
If the Siemens 20Amp 1-pole arc-fault circuit breaker is wired correctly and there are no problems with the circuit that it is protecting, when first turning it to the ON position, the amber light will come on then go out after about 10 seconds or so.
If the breaker is wired incorrectly or there is a fault in the circuit the amber light will stay on.
Nov 07, 2010 | Siemens 20Amp 1-pole arc-fault circuit...
The garbage disposal & overhead sink fixture run to the same Square D Qob120 1pole 15amp 120v Circuit Breaker . After a week of consistentlu tripping, the breaker won't allow itself to reset. ...
I would start by replacing the breaker. If a new one trips then check ground and wiring. If it still trips then there must be a problem with the garbage disposal. let us know
Sep 21, 2010 | Square D Qob120 1pole 20amp 120v Circuit...
Suspect that a 15amp heater tripped the 15amp breaker. this happened a couple of times. now when the 15amp breaker trips a 20amp breaker also trips. the heater is now unplugged and the 20amp can be reset...
You Know for a 15AMP unit it really should be on it's OWN sub-main, Ordinary House sockets are usually only 10AMP rated. This WILL overload any normal household wiring. You also need to get this unit checked out. to see if you have any "Earth leakage". Also at 115volts and 15Amps that equal a 7.66 OHM load....Be careful.
Feb 03, 2010 | Heating & Cooling
Opened breaker to change light switch.closed breaker numerous times before it engaged.
When you relaced the light switch, did you use the "quick stab" holes on the back or the side screws? The arc fault breakers can trip if using the quick stab holes on the back because they may not make a tight contact. This could be represented if the circuit breaker trips when the light switch is turned from "off" to "on". Try connecting using the screws on the side of the device instead.
Jan 18, 2010 | Siemens 20Amp 1-pole arc-fault circuit...
Why is my air handler fan motor tripping the 20
sounds like fan motor is going bad - replace
Jun 15, 2009 | Heating & Cooling
General Electric 20amp 2-pole GFI circuit breaker Logo
279 people viewed this question
Top General Electric Electrical Supplies Experts
Rob Bridges
Level 1 Expert
ken skalski
David Harrelson
David Harrelson
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
