Question about Dell LATITUDE C640, P4 1.7G,256/20G,14.1,CDRW,NIC 5+ PP01L PC Notebook
Hi my name is Shantelle I get the default beep on
Hi my name is Alycia I get the default beep on my laptop but I can't play sound files
  • 37 Answers
May be the sound is muted in the machine
Posted on Nov 13, 2009
Sound recorder
Please check all of the settings options under the Control Panel - Sound.
Mar 09, 2014 | Toshiba Computers & Internet
Hi; I am using HP laptop DV600. It was running fine. Still running fine but sometimes seems a little bit busy. i normally use it on bed/soft place so it also got too hot then i raise it up in air...
hello,
in the first place if you wana use laptop in bed is no problem but try to put him on someting that will keep him a litlle rise so he will take air(for a laptop taking air is the way he cool precesor and chipset)
i am 90% sure that the error is from the high temperature, all computers got a self protecting system that will shutdown auto if temperature is high, and the fact he is sometime seams bussy is the same from high temperature
i think some lint and dust is deposit in the air cooling system, for you will be a litlle dificult to open it and clean it, but i thing if u will buy a cooling pad for it will be ok, and u will use the pc in bed whit out heating him.
best regards
Sep 22, 2011 | HP Pavilion dv6000z Notebook
Will not play any ps3 games or movies
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Thank you
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
When i turn my IBM THINKPAD R50e on it just beeps 3 times then turns off
Hi:
I checked on a beep code for your IBM laptop, and the only code listed with 3 beeps is:
One long, two short beeps System board failure; Video adapter problem; LCD assembly failure
None of these codes sound like an easy or quick fix for you.
If your code is not one long, and 2 short beeps, repost and update!
Feb 10, 2010 | IBM ThinkPad R50e Notebook
Same problem
hi, there could be a hardware conflict, can you please reset your bios settings to defaults?
1. reboot your laptop
2. press "F2" - you should see a BIOS menu
3. Look for a keyword "reset to defaults"
4. Save and exit.
Aug 09, 2009 | HP Compaq Presario V2000 Notebook
How do you change the message on my GE 28821FE2-A cordless phone?
1. Make sure the answering system is ON. 2 . Press and hold the announce button until the speaker announces “RECORD ANNOUNCEMENT AFTER TONE“. 3 . Begin speaking after you hear the beep. 4 . Release the button when you finish your announcement. NOTE: If you choose not to record an outgoing announcement, a default announcement plays instead. To return to the default announcement after you have recorded your own outgoing announcement, press the announce button and release it when you hear the beep. Or, press the delete button while the announcement is reviewing. Sample Outgoing Announcement Hi, this is (use your name here), I can’t answer the phone right now, so please leave your name, number and a brief message after the tone, and I’ll get back to you. Thanks. NOTE: The maximum recording time for the outgoing announcement is 2 minutes. Reviewing and Choosing the Announcement Press and release the announce button to review and select this one as your outgoing announcement. NOTE: Press the PLAY/STOP button at any time to stop playing the announcemet
Mar 25, 2009 | General Electric 28821FE2 Phone
Amr files
hi,
connect your phone in file transfer mode and then browse the phone memory's folder sounds.
there u will find the recordings. on other way is u note down the name of ur ant recorded file.
connect ur phone to pc in file transfer mode and search the memory card and the phone by the same name that u noted down using windows search option. ull surely find them
and u'll need apple quicktime to play amr files.
Jan 02, 2009 | Sony Ericsson K800i Cellular Phone
No sound
Just reinstall ur sound drivers again ... it will reset it to default!!!
May 21, 2008 | Dell Inspiron 6400 Notebook
Would like to record greeting
Here is a link to the instruction manual (5.06MB): http://www.home-electronics.net/GE/ProductDownloads/25881EE3_IB.pdf Recording the Outgoing Announcement For best results when recording, you should be about nine inches from the microphone, and eliminate as much background noise as possible. 1. Make sure the answering system is ON. 2. Press and hold the announce button on the base while you record the announcement. 3. Begin speaking after you hear the beep. 4. Release the button after you finish your announcement. If you choose not to record an outgoing announcement, the default announcement plays. To return to the default announcement after you have recorded your personal announcement, press the delete button on the base while playing the announcement, or press the announce button and release it when you hear the beep. Sample Outgoing Announcement Hi, this is (use your name here), I can?t answer the phone right now, so please leave your name, number and a brief message after the tone, and I?ll get back to you. Thanks. Reviewing Announcement ? Press and release the announce button to play your outgoing announcement.
Mar 04, 2007 | GE 25881EE3 Phone
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
