Question about Nokia 1112 Cellular Phone
Phone does not read/recognize SIM card
Following message appears when phone is switched on (with a SIM card installed): "Insert SIM" The phone does not read/recognize the SIM card even when tried with other SIM cards.
  • 135 Answers
Plz restore ur mobile
Posted on Nov 13, 2009
My samsung j210 is coming up with sim lock and I
How to enter code in Samsung J210 ?You can enter unlock code using three following instructions:
1. Insert a foreig sim card (the sim card which is not supported by Your phone)
2. The phone should ask for an unlock code
3. Enter Unfreeze or Defreeze code ( unsuccesfull message may appear )
4. Enter NCK or Network code
The phone is now unlocked
If your phone does not ask for the unlock code:
1. Turn on the phone with original Sim card or without Sim card
2. Enter #7465625*638*NCK/Network#
The phone is now unlocked.
1. Turn on the phone with a foreign (Unaccepted) Sim card
2. Then enter the following sequence:
#0199*Unfreeze/Defreeze#
#0111*NCK/Network#
#0121*SCK/Subprovider#
#0133*SPCK/Provider#
Sep 29, 2014 | Cell Phones
Insert sim
Is your sim card in the phone? Make sure it is inserted in there correctly and if it is and it still gives you that message the phone has a bad Sim card reader and although your sim is in the phone it is not reading it.
www.usedcellphoneshop.com
May 28, 2010 | Motorola Mobility RAZR2 v9 Cell Phone
IT SAY SIM LOCK AND ASKING THE CODE
This may not work on all Samsung phones!
THIS IS THE TEMP UNLOCK CODE FOR A SAMSUNG PHONE
Do this at your own risk:
Instructions
Press *#06# and write down your IMEI
Unlock Codes
Code 1: *2767*688 then your IMEI and then press #
For example *2767*688352708000828246# (Everything before the / for C225)
Code 2: *0141#
Code 3: 00000000 (8 zero's)
Entering the Codes
1. Switch your phone off. Remove the original SIM card 2. Insert another SIM card from an alternative network. Power up your phone. You should now see the "Wrong Card" message. 3. Type Code 1 into your phone, if this is entered correctly your
phone screen should now turn black and reboot itself. (C225 doesn't go
black but does reboot) 4. After the phone reboots the SIM card will be recognized and your
SIM will work. Be patient while your phone reboots and DO NOT press
any keys. At this point the phone is "Temporarily" unlocked.
5. Now at your idle screen type in Code 2 (*0141#) and hit the call button.
This should give you a message saying the phone is "Personalized". 6. Power off the phone and insert the original SIM, then power up. 7. At the SIM code prompt, it will ask you to enter a password. At
this stage enter Code 3. 8. After entering hit "OK" and your phone should complete initialization.
[/b]Instructions[/b]
Unlock Codes
Code 2: *0141#
Entering the Codes
any keys. At this point the phone is "Temporarily" unlocked. 5. Now at your idle screen type in Code 2 (*0141#) and hit the call button.
Your phone is now Permanently unlocked.
Another easy way is you put in a foreign sim put in the code *2767*2878# much easier and works just the same.
*2767*688 <your IMEI number>
Jan 09, 2010 | Samsung SGH-X820 Phone
Screen reads insert SIM and Sim is installed?
If you tried another sim in your phone, this could be the result. Nowadays, some phones "recognize" the original sim card and may reject another. You might have to get with your provider to clear this up.
Hope this helps... Good luck.
Sep 29, 2009 | Motorola Mobility V557 Cellular Phone
E71 memory card unreadable
please check it with another battery
May 03, 2009 | Nokia E71 Smartphone
Samsung D500
Make sure you have insert SIM card, and it is inserted properly in its place.
Jan 04, 2009 | Samsung SGH-D500 Cellular Phone
Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Nov 26, 2008 | Nokia 6080 Cellular Phone
Sim
take it to motorola's service center they will help u for that and can not give u any idea before seeing ur phone but they will solve ur problem
Jun 06, 2008 | Motorola Mobility L6 Cellular Phone
Samsung e-250 i need unlock code
Please follow the instructions carefully! Following are the 12-point instructions to unlock your Samsung E250 phone:
1. First do a CUSTOM RESET by tying in:
*2767*2878#
(Phone may display foreign language – don't worry! The last digits after the * will appear as - - - -; this is normal)
2. Turn off your phone
3. Take the battery and SIM out of the phone
4. Take a wrong network SIM (a SIM the phone does not currently accept) and insert it ONLY HALF way in, so when you turn on the phone it won't detect the SIM. Very important so the phone won't ask for network password and will show "Insert SIM" message.
The process of inserting only half of the SIM. I advice you to take care and do it with a soft approach as you might not have done this before.
5. 2. Now put the battery in carfully behind the protruding SIM card and switch the phone on. The phone must show "Insert SIM" message.
6. 3. Without turning off the phone, now push the SIM card all the way in, at this stage the phone must continue to display the "Insert SIM" message with the WRONG SIM inside.
7. Now make a FULL RESET by typing: *2767*3855#
9. Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
8. The phone should reboot working with "wrong" SIM inside. (Do not turn off the phone)
10. Disable network lock by typing: #7465625*638*00000000#
12. Check this is done with *#7465625#
If your phone is not unlocked please retry the above ensuring all steps are followed to the letter, 9 out of 10 people who have problems have made a simple error and find that when they repeat all the steps it works.
Jan 08, 2008 | Nokia 1600 Cellular Phone
Phone doesn't recognize the SIM card
The sim card holder has a tiny slide mechanism. After inserting the sim card and pressing it against the body of the phone, place your finger over the card and slide it gently forward. The tiny plastic part that holds the card will snap it into place. Hard to explain, but it will work.
Dec 17, 2007 | Motorola Mobility V66 Cellular Phone
Nokia 1112 Cellular Phone Logo
1,196 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
