Question about HP Compaq Presario 2200 Notebook
WHEN i TURN ON THE PC.. A BEEPING OCCURES.. NO SCREEN ON MONITOR.. RAPID BLINKING ON ONSWITCH FOR MONITOR.. RED LIGHT FLASHING .. LOOKS LIKE A SUN ..
  • 37 Answers
Display problem go to the nearest dealer or repairer
Posted on Nov 13, 2009
TV model # 42631 has a continuious green light blinking rapidly
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Electro help
Jan 16, 2014 | Mitsubishi Replacement Oem V33 Pwb-dm...
Hp w2408h monitor flashing red green black blue white
Jan 10, 2014 | HP W2408H 24-inch Widescreen LCD Monitor
RED BLINKING & BEEPING LIGHT COMES ON WHEN I TRY TO TURN ON
I would go back to make sure that its plugged in correctly. What is your PC doing when you see the Red blinking light on your hard drive? Do you hear any beeps?
Feb 20, 2013 | Computers & Internet
Inspiron 1501 wont start
Does it look like it is running with the exception of the screen being black?
Does it ever post anything on the screen when you hit the power button?
Beep tones and blinking lights tells thetechnicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lightscontinuous.
Apr 06, 2012 | Dell Inspiron 1501 Laptop
Monitors will not turn on due to a power spike. Tower makes a beeping noise with a red blinking light. What could be the problem?
The moitors did not turn on at all after the power spike?
If that is the case, probably some electronic components were burned due to power surge damage.
I advise you to contact the manufacturer for repair and your local electricity supplier.
The beeping noise and the red blinking could be indication that no monitor is plugged in.
Jul 06, 2011 | HP xw6400 Workstation - 2 x Intel Xeon...
Tower is beeping and monitor on/off switch is blinking
I have not solved the problem of the blinking on off switch, but I have solved the problem of the monitor attached to my laptop waiting so long to start up. I never shut down the computer and I never hibernate it either. I leave it on 24 hours a day.
May 19, 2009 | Acer Computers & Internet
Dell E173FP Screen blinking red, green, blue, white
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Apr 16, 2009 | Dell E173FP 17" LCD Monitor
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
HP Compaq Presario 2200 Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
