Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Sharp Aquos LC46D64U
I just got a 46inch Sharp Aquos, and the sound doesn't work when I hook it up to the coax cable, I will have HD digital cable box come tomorrow, should that work fine then?
  • 1 more comment
  • Anonymous May 09, 2008
    Somewhat the same problem with the 52".  No sound from the TV speakers - works great with receiver however, nothing from the TV.
    The TV is on "fixed" - is not muted and the sound is up.
    Any suggestions?
    Thanks
  • Anonymous Feb 02, 2009
    i bought a sharp lc46d64u aquos i have picture but no audio
  • Anonymous Mar 16, 2014
    The TV works fine, the picture is clear, but no sound is coming from the set. I changed the cable box and it still doesn't work
    Champion:
  • 208 Answers
No reason for the audio not to work on the RF cable. Check under menu and option and make sure audio is set to fixed and not variable.
Posted on Feb 05, 2008
How do i turn the captions off on my sharp aquos 65
It depends on your connections. If you have a an antenna, standard cable from the wall, or a cable box connected with a coax cable u will have to turn it off using the CC button located under the panel on the bottom of you aquos remote. If your cable/satellite box is connected any other way besides coax, u will have to turn off the closed caption using the remote for that device...hope this helps.
Jan 09, 2010 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
No Audio
good day sir! are you sure your cables are in good condition?
Oct 14, 2007 | Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD...
I have a comcast digital cable box,SHarp Aquos HD TV, Onkyo r430 receiver and a Sony BluRay player hooked up via HDMI to TV. Blue ray input to Receiver is coax. However, I can not get any sound out of hte...
digital input must be enabled, via the onkyo remote or thru the front panel . without the manual or remote your screwed, i have the same problem ,but if you have the remote you just have to play around with the sound settings on this input only sorry i coudnt help more ohmega1080@yahoo.com
Jun 21, 2009 | Tvone TV-207 Television
Set up
The specs I am reading online are saying that it has digital coax connection. If your hooking up hd cable or hd satellite box some of those have a digital coax output on them. If your hd cable/satellite box only has optical out the system you have says it comes with a optical to coax converter which is pretty cool. So you should definately be able to hook up that sound system to your cable/sat box digitally for best sound. The only other way would be to run stereo red,white cables from your cable/sat box to your stereo as a last resort.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 09, 2008 | Philips LX3950W System
Finding a set top box
Do you mean a freeview box? if so any freeview box will work via thw scart.
Nov 04, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Connection problem
The best hook up for this unit is to use the hdmi if your samsung box offers hdmi output. The panasonic vcr should be hooked to any one of the composit video inputs with the yellow video cable and the red and white audio cables. If the vcr does not have composite output then use a rf (coax cable) to antenna a input and put the tv on channel 3 or 4 as vcr is set for.
Jan 13, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sound
This hapen only on HDMI conection. Try to update the firmware, but beeing in warranty you should call an authorized tech. If your from Montreal area I can do it for you.
Nov 30, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sound, but no picture
The hdmi inputs on this unit go directly thru the main digital pcb. and the component inputs feed thru the av pcb then to the main pcb. If the composit hook up do not work and hdmi inputs do work the unit has a bad AV pcb.
Nov 08, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
How can I take advantage of digital cable?
No digital sound comes from Digital Coax or Optical and in order to utilize a digital signal u need HDMI or Component although component wont be truly digital. Try running everything to the TV then the sound out of the TV into the sound system. If its a high def source like high def cable box then use the optical conection on the back of the aquos and plug than into your surround system. if ur system doesnt support Optical or digital coax then you need an updated surround system. If i misunderstood your question im sorry. If u live in CT though stop by Circuit city in North haven. either myself, Dave, or my associate Justin should be able to help you out. and dont worry we're not on commission or anything.
Dec 17, 2005 | Zenith XBS344 System
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
287 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
