Question about Refrigerators
The appliance is hot to the touch in the divider between the freezer and the refridgerator. It is a double door refridgerator.
  • 180 Answers
More than likely either your condensor coils are clogged with lint and dust, or your condensor fan is not running any more.  The condensor coils run through the middle of the fridge, it should be a little warm, but if it's hot, they are not getting cooled properly.  First pull the panel in the back of the fridge off, and check the fan.  It should be running anytime the compressor is running.  If it isn't working check the voltage going to it.  If you have 120 vac going to the fan replace the fan.  Also check for obstruction, something could be physically preventing the fan from turning.  If the fan is working clean your condensor coils which are located either under the fridge, or next to the compressor.
Posted on Nov 13, 2009
The beam in middle of refridgerator where both doors rest against while closed is too hot to touch
Is the cooling fan for the compressor working? There is a coil of the condenser line that runs around the freezer side. This will get hot but the cold freezer side keeps it form not getting too hot. It could get very warm if the freezer is not cold yet.
Sep 10, 2014 | Kenmore Refrigerators
Freezer working but refridgerator at room temp. Door seal hot.
either the evaporator coil is iced up which means the defrost heater is bad,the defrost control is bad or the damper vent door which throttles cold air in isn't opening fully from the freezer to refrige,the evaporator fan isn't running or if electronically operated the main board behind the unit can be bad on these as this board controls all electrical issues
Jun 20, 2010 | KitchenAid 19.7 Cu. Ft. Side-By-Side...
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Divider between freezer and fridge is HOT to the touch
That is a heat strip to prevent condensate near the door seals and yours is possibly shorting out because the control fo it is defective. Send me the model number for your Roper and I will look at the diaqrams to confirm my theroy. Thanks, Sea BreezeEnter your model number at the link below and it will take you to the parts and photos.http://servicepartstec.blogspot.com
Jun 05, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Whirlpool Side by Side - Overheating
HI thanks for your question. the heat between the two doors is normal. its heated there to stop moisture, from hitting a cold surface , and turning to water, so its normal. but pull fridge away from the wall. remove the back panel by the compressor. clean all coils. thanks the appliance doc. please rate my answer. thanks
Oct 13, 2008 | Whirlpool Refrigerators
Refridgerator
Hi. thanks for the question. the heat between the doors is normal . to solve . pull the fridge away from wall .remove back panel. clean all lint in coils .Dust in the coils causes the heat between the doors to get warmer . so cleaning of coils. will solve the problem thanks the appliance doc
Oct 04, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
