Question about Husqvarna Chain Saw 20" Bar
How to set high and low adjustment for 365 special
  • 1 more comment
  • brant70 Nov 13, 2009
    no tamper resistant caps on this model, i just wasnt sure if the proceedure was different for fuel injection apposed to a carborated model. the local saw shop couldnt tell me for sure.
  • brant70 Nov 14, 2009
    thanks guys, i got it. this one is different. the high needle setting at a half turn out, and the low at a quater out. please note that the low needle only sweeps a half turn total. anyway, saw runs great with this setup at 7000 ft elavation. thanks.
  • dontbother10
    dontbother10 May 11, 2010
    Start at 1.5 turns from lightly seated then tune for best performance. Your saw is probably fitted with tamper resistant caps mandated by the EPA. Have you considered a good local chainsaw seller/mechanic?
    President:
  • 2,220 Answers
I suggest you download your IPL. I find they answer many questions.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Posted on Nov 13, 2009
  • dontbother10
    dontbother10 Nov 13, 2009
    Some of the newer saws have rev limiting ignition systems. Not sure about yours but if yes they really complicate what you are attempting.
  • dontbother10
    dontbother10 Nov 14, 2009
    That seems worrisome lean to me. Please go here and do a search for your saw;
    ArboristSite.com Chainsaw thread (free to join)
    http://www.arboristsite.com/forumdisplay...
    This is a collection of enthusiasts, professionals with a few certified chainsaw mechanics thrown in for good measure. Someone here has your saw, and has been where you are. It costs nothing and I think you might make a few new friends. GL
    Lou
What is carburetor setting on a2.3 chainsaw
There is no fixed carburetor setting on these engines, just two screws to adjust low-end and high-end operation. Special tool may be required, there are about a half-dozen screw head standards. Check eBay for tool. Get the engine to run and idle fast (idle adjust) so it doesn't stall, adjust low-end screw so that engine doesn't hesitate or sputter when accelerated. Adjust high-end screw to run fast and smooth on full throtle. Readjust idle to normal.
Oct 28, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Find 3 squares that add to 365 to show that 365 is a special number
[3, 10, 16], [4, 5, 18], [5, 12, 14], and [10, 11, 12] all work. Of course, there are an infinite number of numbers that are the sum of three squares.
Aug 22, 2012 | Office Equipment & Supplies
Where can I get the special tool to adjust the jets on the carb.
The special toll your looking for is a thin bladed screwdriver. Some carbs have and idle and a "H" (high) adjustment only Others have third setting for "L" (low). The adjustment for idle (top of carb) is a personal judgment call but it should remain running at a low RPM. The adjustment for "H" Is done with full throttle and to the pint that it just does run at full speed without missing. DO NOT set it too lean (clock wise) or you will end up with a short lived blower. As far as setting the "L" speed (on models so equipped) you dial that one in by allowing the unit to idle then rapidly accelerate the engine to full speed. If it hesitates you turn it no more than 1/8 th turn each time and keep repeating the accelerate to full throttle rapidly routine until the hesitation stops. A few of these models have a plastic cover over the "H" adjustment screw. On some of them you can do about 1/4 turn with the cover installed but have to pry it off the jet screw head if further adjustment if required.
Thanks for choosing FixYa.
Kelly
Aug 31, 2010 | Ryobi Backpack Blower 25.4cc
How to adjust the low and high settings on the carb
With all the new EPA guidlines on emissions there are many new type of carbs.The older type was easy, If its a walbro or zama brand and it has 2 adjustment screws as well as an Idle speed, preset the low and high at 1.25 turns out from set, start the saw, run it to full throttle,adjust the high speed needle counter clockwise untill you hear the engine start to flutter. You want to year the flutter about once every 4 seconds.then let it idle,adjust the low speen till it runs smooth then make it 1/8 turn richer. Many of the new carbs require special tools to adjust, not brain surgery, just to keep the air cleaner..
Oct 27, 2009 | Poulan Garden
ToyotaHeadlightAllignment
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Oct 07, 2009 | 1995 Toyota Camry
Husqvarna 51 wont stay idleing
those are the throttle adjustment screws H is high L is Low for the air mixture of the idle.
Jul 28, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to adjust the high/low on pouland P3416, need a special tool?
it can only be adjusted by a certified tech and has to be taken apart and set to factory specs.
Mar 05, 2009 | Garden
Husqvarna 435 wot run at full speed runs at idle fine and looks like u need a special tool for the high low carb adustment
On that model the low adjustment may be factory set, and the adjustment screw is replaced with a roll pin. The high adjustment has a cover on it that can be prised free revealing the screw beneath. Turn screw all the way in (clockwise) GENTLY dont overtighten only to when you feel slight resistance on the screw. then back out 1 1/2 turns. This is the base setting. Turn at 1/8th turn either way until good high speed rev is obtained, but no further in than 1 1/4 turns out, or you will run the saw lean and cause damage. Check and replace your plug if fouled at all.
Feb 19, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Chain Saw 20" Bar Logo
208 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
