Question about Cell Phones
Have blackberry flip phone, blue tooth worked fine,now shows bluetooth:disabled, can't get it to work HELP gene
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cell Phones Master
  • 1,001 Answers
Headphone is easy to pair to most Smart Phones and Bluetooth-enabled Tablet.You can wear the earphone while you're running or working out, and do not have to stick your iPhone in pocket.make you enjoy the exercise. Turning on:Press and hold MFB for 4 seconds until blue LED flashes. Turning off:Press and hold MFB button about 4 seconds until red LED flashes. Connecting: 1.Keep your bluetooth device within 1 meter when pairing ; 2.Make G6plus enter pairing mode as shown:ensure G6plus is off.press and hold Muti-function button for approximately 8 seconds until red and blue LED flash rapidly; 3.Using your bluetooth device,please scan/search for available bluetooth devices select"G6plus"from the list of devices shown; 4.If prompted,enter password or PIN NO:"0000"; 5.If prompted by your mobile phone to connect, select"Yes"(this will vary among mobile phone models); 6.After successful connecting,blue LED of headset will flashes twice every 4 seconds. Multi-pairing: G6 can connect with two bluetooth cell phones at the same time.The general pairing procedures are as follows: 1.Pairing G6plus with device A; 2.Turn on G6plus and make it enter pairing mode again,and pairing it with device B; 3.Operate device A to connect with headset.G6plus has already connected with two devices in this moment. Hands Free: G6plus built-in microphone allows you to answer and end calls.Please use the chart below to execute your desired function. While you're listening to your music,you can control your bluetooth device with the below action on your G6plis ear phones. Specifications: Bluetooth version:CSR8635/V4.0+EDR Bluetoth profiles:Headset ,Hands free,A2DP,AVRCP Operating distance:10M Talk time:4-6hours Standby time:150 hours Charging time:about 1.5 hours Charging Port:Micro USB Amazon com Bluetooth Headphone Charm sonic Wireless Headphone for Gym...
Posted on Nov 23, 2016
  • 541 Answers
Hi to enable Bluetooth follow the steps given below: 1. Click on OPTIONSfrom the main Menu 2. Click on Bluetooth then 3. Click on the Menu key (which is next to track ball) 4. click on Enable Bluetooth If you find any problem please contact the Service Provider of your SIM Thank you for using Fixya
Posted on Nov 13, 2009
I cannot get the enable blue tooth option to switch on. It used to enable when I took the battery out but now not even that works My phone is a blackberry pearl flip 8220
take it in to the dealer, it is a COMMON problem with the blackberry flips, out of 10 people I know that have this exact phone, 6 of them have had to be returned and sent away for repairs, (which in turn got them a new phone.) That is if you have a warranty. If you don't have warranty, then you have to pay for it to be fixed. It just depends on how bad you want the bluetooth...
Mar 20, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I just bought a used blackberry rim and im haveing problems getting it to allow me to bluetooth any pictures or ringtones..please help
For any 2nd hand BlackBerry, you have to format you device and configure newly ,.
for enable blue tooth,
Or follow the below instruction
Screen menu> manage connection> check mark on <blue tooth>
Save
sedngi via blue tooth ,
open any picture or ringtone and press the menu button > send using blue tooth”
receiving via blue tooth ,
Screen menu > media> press the menu button ,”Receiving using blue tooth”
Jul 17, 2010 | RIM BlackBerry 7290
Blue tooth is on and partnered but will not send. It say's service unavailable. The sim card-blue tooth has worked in other phones.
Restart your smart phone and restart your bluetooth as well. Then reconnect with your device. This should solve the intermittent problem.
Regards
Apr 09, 2010 | RIM BlackBerry Bold 9000 Smartphone
Recently just got my new 9700 bold but am having problems with the bluetooth function. I cant seem to receive any files from other bluetooth devices?? I read somewhere that on Blackberries you need to go...
Some blackberry don't receive through blue tooth.,it 's just there for decoration.
look around and see if any other black berry receives through blue tooth....
Feb 09, 2010 | RIM BlackBerry Bold 9700 Smartphone
Bluetooth receive file
first of all make pair with the other phone and then tell some one to send u file via bluetooth ... and then go to ur BlackBerry's media click on option and then click on receive file via blutooth . thats the regular procedure to recive any file via blue tooth on black berry
Oct 10, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
My Bluetooth headset's microphone stopped working
Same Problem Here. Restored the 8220 flipphone to factory settings. Dint work either.
Sep 24, 2009 | Jabra BT250 Consumer Headset
Bluetooth headset pairing won't go away
you can disable blue tooth connections from the connections manager
Jul 14, 2009 | RIM BlackBerry Bold 9000 Smartphone
Bluetooth has stopped transmitting
Make sure your version of bluetooth for the hand held device and the listening device is not an old version. The first generation of blue tooth was able to transmit sound (for phone calls), but not able to transmit stero sound or mp3.
Sorry I couldn't be more helpful... :)
Dec 11, 2007 | RIM BlackBerry 7100G Smartphone
Cell Phones Logo
144 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
