Question about KitchenAid Kitchen Ranges
F3EO comes on when i try to start my oven - KitchenAid Kitchen Ranges
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: my whirlpool oven electronic pad flashing f3eo
The error code E0 F3 indicates that the oven temperature sensor in your range is open. This error code can also mean that the electronic oven control in your range has failed. Disconnect the electricity to your range for 2-3 minutes. This will reset your control if it is just confused.
If the error code persists someone needs to access the back of the electronic oven control and read the resistance of the oven temperature sensor. The sensor is connected to terminals P3-5 and P3-6 on the electronic oven control by two violet wires. The sensor should read around 1100 ohms at 70 degrees
If the sensor reads more than 100 ohms more or less than 1100 it is defective. If the sensor reads within 100 ohms of 1100, the electronic oven control has failed and will need to be replaced.
Posted on Dec 18, 2008
jumptrout51
  • 3361 Answers
SOURCE: F3EO error message
Replace the oven temperature sensor.
Posted on Apr 20, 2009
I have an old Modern Maid double oven. DK 0757. Broiler comes on everytime I try to heat for baking. Any suggestions
It was common for the broil element to come on during the preheat time on older oven controls. When the oven reaches temperature the broil should shut off. If this just started then the points in the broil switch section are welded together and the oven thermostat will need replacing
Mar 20, 2015 | Ovens
When I try and Bake or Broil the oven beeps and gives a fault code of F3EO
HI. Generally, this will be the cause of a failed oven temp sensor. If your unit's orientation is doubled, the top oven sensor will be the culprit. Some model will incorporate a sensor fuse at the wiring harness. Check the fuse, if equipped, for continuity. If the fuse is bad, replace it. If the fuse is ok, replace the oven temp sensor.
F3E0 - Failed oven temp sensor(top sensor if double oven)
Mar 01, 2010 | Whirlpool Ovens
Oven won't come on unless you press bake and immediately hit arrow to 400 degrees. Can this be fixed
Yes, this is most likely a thermostat problem. If you have tried every temp level below 400 and it will not come on until you reach 400 on the dial, then you most likely have a temp sensor switch/ thermostat problem.
I had to assume alot of things here:
1. It is an electric oven.
2. Once you get the oven to start at the magic number and try to dial down from there, the oven turns itself off.
3. It will start up as long as the temp is first set at 400 degrees or higher.
Jan 08, 2010 | Kenmore Cooktops
It seems like my oven gets overheated and then it beeps with a code on it F3EO?
How do you know your oven is overheating? what indications are given that it is overheated/ i ask this beacuse the error code f3OE may not mean the same on each model and you do not say what brand or model you have, also on some models this code means control board failure which is not necessarily due to overheating. If you look in the back of your range, there maybe a paper or plastic envelope pocket with a tech diagram paper; this usually has the error code list on it and it iwill guide you as to the problem. Sometimes the pocket and diagram are located near the bottom of the range in the back (slightly under the unit). Goodluck, Macgivor
Nov 12, 2009 | Kitchen Ranges
Stove flashed F11 and then locked the oven door
HI, this is control failure. the logic chip set is damaged. this is causing these erratic commands and the unauthorized locking of the oven door. you will need ot replace the control in this case.(EOC/clock)
May 29, 2009 | Frigidaire FEB27S5A Electric Single Oven
F3EO error message
Mar 16, 2009 | Whirlpool Accubake RF362LXTS Electric...
My whirlpool oven electronic pad flashing f3eo
Dec 18, 2008 | Kitchen Ranges
I have Whirlpool Gas Range Model SF315PEGW 5. The bake function will not work and appears to through a code i.e., F3EO. Can you tell me what to replace?
will the ignitor glow if it does and its dim the ignitor needs to be replaced if not the control board needs to be replaced
Aug 04, 2008 | Whirlpool Kitchen Ranges
Sharp Microwave Oven Corousel
I replied privately to this, stating it may be the HV capacitor, or possibly the magnetron or transformer and giving links.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 31, 2007 | Sharp R-1480 Microwave Oven
Kenmore analog gas range time bake
try broil if it comes on then it is oven ignightor no big deal to fix
Sep 18, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Open Questions:
Kitchen Ranges Logo
215 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
