Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Washer leaks from both draws,and washer will go on and flash a wrench symbol in display
  • 48 Answers
Looks like a LG is it?
Posted on Nov 13, 2009
What does "wrench" symbol mean in message center?
Wrench means, workshop needed. If it does not come back, no problem. If it keeps coming back, visit a repair shop.
Jul 17, 2014 | 2007 Mercury Mountaineer
I have a Saeco Syntia and a Red Wrench with the #14 came on the display. I have turned on and off and now the yellow thermostat symbol comes up. you can feel it heating up but it does nothing else.
need to tell me when the wrench appears ,at start up ? YES? then most likely "over pressure valve" is broken and machine needs to be serviced by service center to replace the plastic part with a metal parts ,Stop using it or the leaking water will damage the system .
Jan 18, 2014 | Saeco Syntia Espresso Machine & Coffee...
Battery indicator seems fine. Wrench symbol is lit. Chair won't respond to joystick control. Any suggestions? It worked when I put it away a few months ago and now, nothing.
The wrench symbol being lit indicates a problem. Does the wrench symbol blink? when you try to engage the joystick the brakes should try to engage and you would hear them click and the symbol will flash. The number of flashes telling you what is wrong. If the symbol is not flashing and staying on then that also a probem but you can't tell what it is. Either way the chair will have to be checked by a tech that has a programmer to plug into the chair and read the error codes to determine the problem. Check with your provider that sold you the chair to see if they can troubleshoot the chair for you or contact Invacare Tech Support @ 1-800-333-6900 and explain your problem. Sorry I can't give you a definite answer Hope this helps
Mar 07, 2011 | Invacare Supply Group Invacare Pronto M91...
It keeps running and shutting off. The repair symbol is lit on the screen that shows a little wrench
Is this problem with both the drawers or just one of them.
Do you get any other code in the display along with the wrench symbol?
Aug 08, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How can i turn off key symbol
Hello Lucy and welcome to Fixya.
As far as the "signal" activation or de-activation goes, it should be performed before starting a load of laundry and it is as follow's... 1) Turn the program selector to any program as you would doing laundry. Add your items... 2) When you close the door the "start/pause" light flashes... 3) Press the "menu" button until the signal indicator is displayed and flashes ( a small speaker symbol ) as does the start/pause light. If no buttons are pressed within 10 seconds, the current setting will be saved. 4) Press the "select" button until the desired volume or "off" is reached/displayed. 5) Press the "start/pause" button so the program starts and the setting is saved after the cycle has completed. As for the "key" symbol, your washer has a "child lock" program and the symbol indicates it has been activated.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Jun 16, 2010 | Bosch Washing Machines
Leaking water from bottom draw
To put machine into test mode: Press and hold keylock, then press and hold start button. Hold both in until machine beeps (if you have display, it will show all symbols). Press power button- display should now show HO. Press start button until LD shows in display- this tests lid motors. Activate lid motors by pressing keylock button- if you open drawer about 3 inches, you should see lid come down. Pressing keylock again will raise lid. Raise and lower lid several times by pressing keylock button to ensure lid is working properly- if not, lid motors need replacing. Good luck!!
Mar 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The digital display is showing a KEY symbol flashing, and i can't program a new load. What does this mean?
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Sep 30, 2009 | Bosch Exxcel WFX 2467 Front Load Washer
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
"Wrench" symbol and won't power off
I would suspect there is water getting under the machine and tripping the overflow. You're going to need service to determine the cause of the problem. sorry
Aug 05, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
114 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
