Question about Nokia N70 Cellular Phone
Why is it that my memory is already 1g but still it has low memory?
    Guru:
  • 312 Answers
I think you have used phone memory..So change the memory to memory card....for that go to messages in that you will find options like inbox, write new, drafts etc...in that place other than write new and click on options .settings . other. memory in use...change there to memory card..This will get clear...Hope you will succeed.....Thank you,....
Posted on Nov 13, 2009
The ram slots on my ga-81865gm-775-rh-as MB are reporting my ram chips as 512k each rather than 1g each. The chips are 400mhz, supported, Kingston kvr400x643ak2/1g. I've already removed the ram and...
Hi, you can download a manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=2358#manual
Your mainboard supports:
Type: Dual Channel DDR 400 / 333 / 266 support
  1. Max capacity: 2 GB
  2. DIMM slots: 2
* Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount.
Its maybe a setting in the bios or you missing a driver that causes the problem.
Or one of you ram modules is defect.
Sep 04, 2011 | Gigabyte GA-8I865GME-775-RH LGA 775/ 865G/...
Hi! How can I increase the RAM on my Aspire T310? Can I do it myself? Thanks.
Yes, you can definitely do this yourself. Upgrading RAM is one thing that repair places make much money; however, it takes a matter of seconds to complete.
Your Acer Aspire T310 has two memory slots on the motherboard. Each slot can hold a maximum of 1GB each for a total of 2GB RAM. You should see a great improvement in performance.
To save on a long tutorial, I have included a video link. The type of RAM you need can be found at the following link. Kingston is another manufacturer you could check into also.
Please remember to unplug all cords from your computer and be in a static free environment before upgrading your memory. Good Luck!
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=269237BDA5CA7304
Feb 26, 2010 | Acer Aspire T310 PC Desktop
I have installed an extra 1G memory but it has not
Open "My Computer".
Right-mouse-click on the 'C:' drive.
Click 'Properties'.
A pie-chart will display, showing how much disk-space is "used"
and how much is "available".
Probably, the "available" pie-slice is less than 5% of the whole pie.
What Windows did was to "expand" the "paging" file, making it 1GB larger than it was before you added the RAM. So, the amount of "used" space on your C: drive is now 1GB _more_ than before.
So, burn some CD/DVD disks with some of your files,
and then delete the files, after checking that the disks are readable, to make more "free" space on your 'C:' drive.
Jan 09, 2010 | Acer Aspire 5315 Notebook
Memory card not ready
are you getting a format error? the card (if new) should be "ready" already. also you may want to verify in your owners manual that the phone can handle a 4 gig card.
May 18, 2009 | LG CU500 Cellular Phone
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Memory card won't show
Hi there, your problem might have an easy solution the Motorola l7 supports a san disc memory card and every other similar one but im not quiet sure about media cards so make sure of that.
May 20, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Memory upgrade from ddr 256mb to ddr2 1g
there is a jumper setting to slect which type of memory you want to use, check your manual for details on how to change it
1> enusre the rams are in correctly
2>ensure your main board supports the amount of memory and the speed of the memory
3> verify jumper select to correct memory type is set correctly
if the main board aint compatable with the memory you brought that will cause the same problem
Jan 02, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
1g dx
No upgrade possible, max size for this model is 512mb.
See olympus.com for compatability charts
Dec 19, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Installiing memory in inspiron 1000
You compuer comes with this already installed.
  • 512MB PC2100 DDR Memory
  • You can only install another 512MB total 1G.
    To get into where the chip is should be underneath that laptop secured by two screws.  If you find there is no chip inthere already then all you need to do is place the other chip into the slot.  The first is already in there and to get that you have to go through the removing the keyboard.
    Oct 17, 2007 | Dell Inspiron 1000 Notebook
    Nokia N70 Cellular Phone Logo
    47 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
    IT Solution
    IT Solution
