Question about Acer Aspire 6930-6771 Laptop
I have a Acer aspire 6930. Sometimes, my laptop won't shut off, only showing "shutting off" message. I come back after an hour, still not off. What is going on? I have to forcibly turn it off by pressing the power button! Also, my computer freezes constantly, making me use the power button. I try ctrl + alt + delete, but they don't show up either ...
    Sergeant:
  • 267 Answers
Ok sounds like you unit is in very serious need of cleaning and maybe even some virus removal.
to scan and remove viruses ( click here ). install this to your computer and allow it to scan and remove any found threats.
also click start then run or command prompts .
type : cookies.
a page will pop up. you will need to delete everything in this except index. index is a system file and can not be deleted. close this window and empty recycle bin. now you will need to repeat this step but this time you will type in : temp
delete everything in this window. these are the things that will slow your computer down. you will also need to do a disk clean up. and a disk defrag.
after that you computer will be running faster.
also i subjest removing some things from your start up menu. this will slow the computer down from shutting down quickly.
i hope this was helpful.
Posted on Nov 13, 2009
Testimonial: "Thank you so much! But when I do the comman prompt, and type in cookies and temp, nothing pops up!"
  • 1 more comment
  • rain_catcher
    rain_catcher Nov 13, 2009
    ok i need to know the operating system your using so i can give you the correct commands
  • rain_catcher
    ok do the disk clean up. this will delete the cookies and temporary files that are slowing your computer down
  • rain_catcher
    your not typing cookies and temp together right?
    one at a time cookies
    then temp
    you can also do the disk clean up that will delete the unneeded temps and cookies. hope this was helpful
  • 519 Answers
Hi, you don't mention what operating system you are using, but try to do a system restore if using Windows XP or otherwise re-install your operating system as this sounds like a software problem.
Best wishes,
Graemevm
My acer aspire 6930 will not turn on even with the charge plugged in. The light around the power button turns on but after a couple of seconds it turns right off nothing comes up on my screen and the light...
When I turn on my Acer 6930 the screen will stay black but all f the buttons come n to show tht it is running. Nthing happens it is just a blank screen. an anyone help me with this issue?
Oct 19, 2010 | Acer Aspire 6930-6771 Laptop
ACRE LAPTOP CONSTANTLY SHUTS DOWN BY ITSELF
It is either an overheating problem where the acer is shutting off to protect the equipment, or it is RAM that has gone bad.
Try cleaning out all the vents and fans as well as you can. If the unit is no longer under warranty, you may want to open it up if you can to ensure a good cleaning. If that is not the problem, I would investigate replacing the RAM.
Apr 06, 2010 | Acer Aspire 6930-6771 Laptop
Aspire 6930 shut down problem
If you go to the power options in the control panel, it should give you the option to choose what happens when you close the lid
Feb 17, 2010 | Acer Aspire 6930-6771 Laptop
I have a problem with an Acer Aspire 6930, sometimes during startup ut shows a message that it cant find windows and shuts down. After trying again it powers on normally. But i wasnt able to find the...
If it is an older Laptop... it could just be the HD not spinning up correctly or not spinning up as fast as the PC is booting. There is a HD check to the BIOS in the first seconds of the Boot. BIOS doesnt see it... you get the fail.
A good test is after it fails... do a CTRL/ALT/DEL to restart the system... if it Boots then it was the HD not keeping up.
OPTION: Also check to see if the BIOS needs updated and this is a tricky opperation to do... make a mistake you loose your system. This could also help if the condition is common and a patch was created.
It doesnt hurt the to run it the way it is. The Drive lagging like that doesnt always mean the HD is bad. If it occours every single time I would worry. Buy a New HD to be safe and also the newer HD's will help 100% on the Speed of the system.
Jan 02, 2010 | Acer Aspire 6930-6455 Notebook PC
Keys died and pc shut downs
It's definitely not normal. Did you spill something onto the keyboard,
and did it leak through the keyboard into the "guts" of the computer?
Take the computer to a qualified technician, top test that the motherboard of the computer is still 100% working. If it is,
then pay the technician to replace the keyboard,
Is it still under warranty, maybe an "all-perils" warranty?
Dec 29, 2009 | Acer Aspire 6930-6771 Laptop
Have an italian laptop need to change to english
while installing the operating system..it will ask for ur language preference....select english in dat and it will b in english...
Jun 10, 2009 | Acer Aspire 6930-6455 Notebook PC
Where is the wireless connection button on the acer aspire 6930?
The switch for the 6930 is located just above the NumLock key. It actually looks like an LED indicator of a satellite dish, but it's not. It's the button for the WiFi enable/disable. Push it hard...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 06, 2009 | Acer Aspire 6930-6771 Laptop
Key board and touch pad do not work
Did it shut off on the keypad? Sometimes things are being so frustrating that we forget that the keypad has a shutoff that can get bumped. Make sure it's on.
Mar 30, 2009 | Acer Aspire 6930-6771 Laptop
My Acer aspire 6930 doesn't boot up!
sounds like windows are possible hard drive problem
Mar 29, 2009 | Acer Aspire 6930-6771 Laptop
Acer Aspire 6930-6771 Laptop Logo
270 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
