Question about Logitech Harmony 890 LCD Remote Control
I own the Harmony 890 remote. I went to pick it up off the end table last night and the screen was blue. No text or icons. can you help?
  • 3 more comments
  • ckreinhard Nov 14, 2009
    I removed the battery for greater than 60 minutes and did a software and firmware upgrade. The problem still exists. What else can I do?
  • ckreinhard Nov 16, 2009
    I own the Harmony 890 remote. I picked it up the other day and the screen was solid blue - no icons or text. I received previous advice from FixYa to remove the battery for 60 mins and the reload the software and firmware. I did that and it seemed to fix the problem. However 15 minutes later the screen was solid blue again. I removed the battery for 20 seconds or so and the screen back but again only lasted for about 5-10 minutes. Can you help?
    Yes I have removed the battery multiple times. Most recently took it out for an hour. The screen lasted about 10 minutes. Is there anything else I can do or am I out of luck.
  • ckreinhard Nov 17, 2009
    So does that mean that installing a new battery will not do any good? We haven't spilled any liquid on the remote.
    I didn't give you a poor rating. I didn't give any rating.
  • 10,865 Answers
Hello. Thanks for choosing Fixya! The problem you are experiencing with the Harmony 890 remote is increasingly common. If your remote is still under warranty you can return it for a new one. If it is out of warranty you may want to contact the company and complain, siting how common the problem is there should be a recall. Also consider contacting the Better Business Bureau about this issue. There is no customer fix to the Blue Screen Syndrome.
Here is a link to Logitech, the manufacturer of the Harmony 890. This way you can choose your method to contact them: http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/ask.php?section=contact&tabs=1,3,2,4,5
Posted on Nov 17, 2009
    Brigadier General:
  • 3,489 Answers
Have you taken the battery out to reset?
Posted on Nov 16, 2009
  • Kori Policy
    Kori Policy Nov 16, 2009
    i own one too. if you have already downloaded and removed to reset and the problem still exists....... somebody got it wet. unfortunately i have no good news. you will need to buy another. when they are working, man they work great especially if you have a whole system to control.
  • Kori Policy
    got some more info: unplug the charger base from the wall. take your reciever unit and remote to your computer for the updates, once that is done THEN plug in the charger base. my wife just said the same thing youre describing happened to us. i really hope this solves your problem.
  • 4,472 Answers
This is a very very common problem with this remote. If your remote is under warranty it will be repaired/replaced by logitech for free. If it's out of warranty they charge almost as much for a new remote to have it repaired. Here are the steps that may help you.
Step 1 - remove the battery for about 60 minutes. There seems to be a little energy store in the unit and just taking out the battery, counting to 10, and reinstalling it does not work.
Step 2- Do a software update upgrade from the Logitech site. The new firmware level seems to have fixed the base problem.
If you just take the battery out and put it in, it does not work.
If you take the battery out and just hook it up to do a software upgrade, it does not work because the remote gets power from the USB connection so it remains "hung"
Here is the link to the logitech site where you can download the needed software:
http://www.logitech.com/index.cfm/440/3865&hub=1&cl=us,en?osid=1
if you need to you can use the second part of these instructions as mentioned you want to make sure you remove the battery long enough to completely remove all charge from the remote.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=11962&p_created=1244041739&p_sid=et_tKpLj&p_accessibility=&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MywzJnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD04OTAgcHJvIGZpcm13YXJl&p_li=&p_topview=1
Thank you,
lee
Posted on Nov 13, 2009
  • 788 Answers
I have reviewed your problem and have the fallowing for you to aces.
First, try removing the battery and allow the remote to set for a few minutes.
Replace the battery with a new one and check functionality.
Make sure you wait at least 2 minutes before re-installing the new battery.
If this does not work for you, their is really no other solutions for the remote, other than replacement.
Hope this works for you.
Please rate when finished. Thank you.
Posted on Nov 15, 2009
  • John Ray Nov 15, 2009
    Ok, I found other information on your 890 remote, that you may want to try.
    Go to this website,.Logitic.com and re-program your remote.
    You will have to register to use their set-up program.
    It is fairly easy way to set it up. You will need to have the remote connected to your computer with a USB cable when you start. http://www.logitech.com/index.cfm/440/38...
  • John Ray Nov 16, 2009
    Why not replace the battery. Thank you for the poor rating.
    respectfully
Harmony 890 Remote - kids watched a movie last night and now the screen is zoomed and we don't know how to get back to regular view. They swear they only used that remote.
On the remote, press "Devices" and then select the TV. There should be a command on the LCD screen that is called somethine like Zoom, TVZoom, or a ratio such as 5:10 (the numbers could be anything). If not, test all of the commands. One of them will fix it.
Jul 25, 2010 | Logitech Harmony 890 LCD Remote Control
The Harmony 890 turns the TV on and off, but it does not do the other functions.
Hi. You can learn the buttons from the original remote so that they work
In the software, click 'Learn IR' next to the icon for your TV. Follow the on-screen instructions to learn the buttons.
Hope that helps.
Mar 20, 2010 | Logitech Harmony 890 LCD Remote Control
Harmony 890 remote has solid blue screen
Try putting the remote in 'safe mode' before doing the firmware update. I can't think of anything else you can try, but 'safe mode' --> Firmware update often does the trick. Here's how:
Launch the Logitech Remote software on your computer and click on "Downloads" (on the top menu bar). Then, take the battery out of your remote and at the same time you connect the USB cable to your remote (it should be already connected on the computer end) press and hold down the Off button at the top of the remote. This will put the remote in "safe mode". Continue to hold down the Off button until you see the message "safe mode requested" on the remote's screen and the screen starts blinking. Now, since your screen is not behaving properly, you may or may not see this message, but after about 5 seconds you can release the Off button. Now, go back to your computer and click on "Firmware". If the software is able to communicate with the remote, an update to the remote's firmware should be executed. This has solved many a 'blue screen of death' problem. Good luck!
Nov 13, 2009 | Logitech Harmony 890 LCD Remote Control
The power flickered on and off last night and since then I cannot get my Harmony 890 remote to change channels. We have Direct TV. It will control the volumn and turn the tv on and off, but will not...
You DirecTV device may have been reset ack to RF. You'll have to make sure the device is set to accept IR commands in order for the Harmony remote to work on it.
This link will help you.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12985
-D
Oct 31, 2009 | Logitech Harmony 890 LCD Remote Control
Harmony 890 just went dead. Nothing. Nada. Not
I have an 890 also. I've found that the remote doesn't always charge when it the charger. I have to put a rubber band around it and make sure it shows that the the battery symbol on the display is showing that it charging. Or the battery isn't taking a charge anymore and I'd try to replace it. Doesn't really hold a charge very long either.
Oct 27, 2009 | Logitech Harmony 890 LCD Remote Control
My logitech harmony 890 remote's screen is blank. it still works fine, but the screen is blue and blank
This seems as though it may be a hardware issue. Please try contacting logitech through phone support of email support under the contact page on www.logitech.com
Oct 02, 2009 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony 890 Pro - Blank LCD Screen
Replacement screens can be found on ebay for around $25-$30. I was having the same problem as everybody else, and none of the solutions posted online worked for me - software, firmware, battery pulls, safe mode, etc. I replaced the screen in about 5 minutes and was back up and running.... I almost bought a new remote, but figured I'd try the $26 screen first.... Glad I did..
Sep 29, 2009 | Logitech Harmony 890 LCD Remote Control
Blank Blue Screen, but buttons still work
I had the same problem and when I took the remote apart the ribbon connecting the lcd screen to the remote controller board was sheared. The remote was dropped and the impact caused two of the traces on the ribbon to tear.
Customize LCD icons & tect
In the program menu on the computer that is used to sync the remote, go to the "Activities" section and select the button at the bottom for "New Activity". From their, program in your appropriate equipment to follow the activity that you intend to use in each respective activity. The icons unfortunately are pre-made, so you will be limited to what ever icons for activities Logitech has created with their latest software/firmware. After you have programmed in your new activities, perform an "Update Remote" and test it out.
Apr 28, 2009 | Logitech Harmony One Advanced Universal...
Harmony remote screen is blue no icons
Hi. If the firmware update does not solve this, then it may be a hardware issue. Here are the steps to update the firmware on the remote.
1- Launch the software and log in to your account.
2- Click on 'Downloads' at the top of the screen.
3- Click 'Firmware' and follow the steps to update the firmware on the remote.
4- Update your remote.
Jan 17, 2009 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony 890 LCD Remote Control Logo
63 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
Andrew Taylor
Andrew Taylor
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
