Question about Bang and Olufsen Beocenter 9300 Shelf System
'Beocenter 9000' sounds problem
The receiver doesn't work properly. The Radio, CD, and Cassette all play as they should, and I tested it with headphones and the sound has a light type hum in it, that sounds like a grounding type issue. The sound doesn't come thru very well and is also very scratchy, and isn't clear. Both channels seem to be working, as you get the same type sound from each.
    President:
  • 1,950 Answers
Did you check the cables including the power? Maybe some wires are overlapping causing interference/maybe some wire got damaged. Check also the outlet you are using (try another outlet).
Posted on Jan 08, 2008
    Novelist:
    Scholar:
  • 136 Answers
Hi talenso,
as the beocenter 9300 i assume its at least 7 years old. This model has 2 transformers in them one for when it is on standby and one during operation. I suspect one of these has degraded over time.
My best advice is see if you can go to your local store and buy one of those power boards that regulate the voltage coming into the unit. This may solve your problem, but my gut feeling is one of the transformers needs to be serviced.
good luck
smeags.
6ya staff
SOURCE:
Used isuzu radio/cd/cassette will not work in my vehichle, does it need a code?
If it works @ all it doesn't need a code - it's a bad CD player.
td
Nov 05, 2012 | 1998 Isuzu Rodeo
Beocenter 7007 lights but no power
It is likely the audio output ic has failed, check the speaker wires for shorts, if okay! you will need a professional to take care of this.
Mar 21, 2012 | Bang and Olufsen Beocenter 9300 Shelf...
Beocenter 9000 won't play cd,help
The most common cause of not playing cds is c2103 on the pcb under the cd mech.Try cleaning the laser lens also.
Jan 04, 2011 | Bang and Olufsen Beocenter 9300 Shelf...
I have a Bang & Olufsen Beocenter 9000 with a missing CD spindle
You might be able to get one from online parts shop CPC, they stock B & O parts. You can worry about if you can fit it when you've got one!
Dec 24, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Problem playing CD's
beosound 9000? have you moved the unit.this unit requires cd mech suspension adjustment depending on how it is placed,eg. vert. flat horizontal.check handbook and adjust as required.if it has not been moved then workshop repair needed
May 17, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Broken cd player
The motor is last thing to gone before you go to service check the rubber belt which connect the motor to the door gears.Your set is 20 years old and this should be the problem and easy to fix
Feb 07, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
407 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Damen Wong
Damen Wong
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
