Question about HP Pavilion G60-235DX notebook
I can't figure out how to adjust the volume on my New HP Pavilion G60-458dx Laptop Notebook
  • 8,197 Answers
Integrated numeric keypad and volume keys Can be used like the keys on an external numeric keypad.
Adjusts system volume when pressed in combination with the fn
key.
Page 3 of the manual on link below.
http://h10032.www1.hp.com/ctg/Manual/c01540485.pdf
Good Luck
Posted on Nov 13, 2009
Testimonial: "Thankyou so much! I've always had Gateway...HP is so totally different! U saved my day! "
Left speaker stoped working.
Ramon go to control panel, sound and check sttings.
Are the speakers set as laptop etc. While there adjust your volume as well.
Aug 21, 2013 | HEWLETT-PACKARD HP Pavilion G71150us...
Using skype, i can't hear my person. do i need to keep my speakers on?
Hi phyllisz10
Yes you will need to keep your volume on on your computer.
Adjust the volume of the speakers by left clicking on the speaker icon
If you right click on the speaker volume then it will take you to a window that will have adjustments and mute controls, make sure none of the mute boxes are checked.
Be sure to check both boxes because they both have mute control boxes.
Please take time to rate me
Sep 05, 2011 | HP Pavilion dv2000t 14.1" Notebook Laptop...
I have an HP Pavilion dv 7 notebook pc. not sure why... in the middle of my screen a bar shows up with the word "volume" and a sound bar indicating that volume is twitching between 35% and 50%...
The volume slider on your laptop is failing or having problems, I have had this issue my self it is usually caused by dirt and grime, so you may want to give it a good cleaning or residual heat from the processor. I'm posting the link to an hp support thread below, with several other fixes not mentioned here. I hope I could Help.
http://h30434.www3.hp.com/t5/Notebook-Hardware/HP-Pavilion-dv7-1240us-volume-control-touch-sensitive-not/td-p/39547
Jun 21, 2011 | HP Pavilion dv6000z Notebook
When I use my headphones for skype of my Pavilion dv7, the microphone dosn't work. Why???
Assuming that the microphone jack is correctly connected, go to sound properties in Control Panel and check that microphone is checked and that the volume is correctly adjusted.
Hope this helps
May 09, 2011 | HP Pavilion dv2000t 14.1" Notebook Laptop...
I'vs had my HP Pavilion Dv9000 laptop about 2 months now, and it has been great. recently however sounds have only been coming from the right sound channel. The left side just makes a starng buzzing noise...
There is a problem is the sound card. The HP laptop should be still under warranty, take it to the supplier to get it repaired under warranty. If you try to fix it yourself you most likely will void your warranty.
Oct 24, 2009 | HP Pavilion dv9000z Notebook
I have three problems with my hp pavilion dv5 notepook
I have the same laptop but I can't help with the touchpad issue (must be a hardware issue b/c mine works fine....try unstalling the driverm then reinstall the driver). The problem with the volume I can help you with: go to start and type in MSCONFIG and click on the startup tab, then uncheck the onscreen display for quick touch (the name may vary) item.....then reboot....now the volume will still change without showing you the annoying window (takes care of the random volume changes also & if the volume doesnt react, just tap the Stop button a couple times then change your volume)
now, the overheating and shutting down issue: go to HP's support site support.hp.com and type in the exact model number on the bottom of your laptop. now you need to go to the drivers and downloads section. there scroll down til you see BIOS. download and run this b/c it updates the laptop to where the fan inside will run faster and more often to compensate for the laptop running hot. helped mine out a lot.
Another thought (volume): uninstall just quicktouch in Programs and Features from the control panel. it gets rid of the annoying ticking when you adjust the volume....helped me out a bunch.
Oct 26, 2008 | HP Pavilion dv6000z Notebook
Pavilion dv4000 microphone
sorry no build in microphone use ext....
Apr 28, 2008 | HP Pavilion dv4000 Notebook
How do I turn my internal microphone on, please help
1)Double click on the speaker icon in the system tray to bring up windows volume control. 2)Go to options, then properties. 3)Select adjust volume for recording. 4)Make sure microphone is ticked. 5)Click ok. 6)Select the microphone in the windows volume control. Your microphone is now on. Just set the appropriate volume for the mic.
Aug 02, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion G60-235DX notebook Logo
346 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
