Question about Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n CX13A011 13 GB Hard Drive
Can I use my Quantum Fireball in almost any computer
    Sergeant:
  • 267 Answers
No not almost any but most. you may have to move the jumper around to trick the unit but most fireballs are compatible with most units.
Posted on Nov 13, 2009
5 Suggested Answers
  • 97 Answers
SOURCE: Drivers download
Hard drives do not have an installation CD unless you are referring to Windows installation CD and installing Windows on the hard drive/
Posted on Dec 07, 2008
ginko
  • 19396 Answers
SOURCE: I am looking for a Quantum Fireball 20.5 GB hard
The board alone is not available for sale. To recover the data you will need to buy a 20GB Fireball with same board and swap the control board.
You can buy a 20.GB Fireballl QMP20000AS-A from links below:
QUANTUM QMP20000AS-A - Buy Now at Cuetech, Inc.
QMP20000AS-A DELL 20GB 3.5" IDE 7.2K HARD DRIVE
Quantum QMP20000AS-A Fireball Plus 2 QUANTUM FIREBALL PLUS AS 20GB HARD DRIVE QMP20000AS-A -
Posted on Oct 22, 2009
MalKontent68
  • 748 Answers
SOURCE: Different WIndows operating systems on two hard drives
1) Try if Cable Select will work for you, meaning that the existing HDD will be Master, and the Quantum will be Slave. If there are problems in identifying the drives by BIOS, manually set the existing one to Master, and the Quantum to Slave.
2) You don't have to install anything on the second drive. The operating system has to be installed on the primary drive, from which the system boots.
3) If the Quantum drive does not contain anything useful, it would be advisable to go to Management Tools, Disk Management and delete the partition from it, re-create it, and format as NTFS - under WinMe it was surely formatted as FAT32, which has a file size limit of 2GB and doesn't let you set any access permissions.
If you don't need NTFS, then at least re-formatting the drive would be advisable, as it's the simplest way to get a clean drive, without unwanted stuff (like WInMe, programs installed on it etc.) and no data fragmentation, that occurs with time and slows down the drive operation.
4) You might need to go to Disk Management anyway to assign a drive letter to your newly attached drive - most probably your existing drive is C, your CD/DVD is D, so you'll have to assign letter E to it, or better yet, some letter further in the alphabet, like Q for example - especially if you use external disk devices, like flash pendrives etc., which already were assigned the letter E when you used them.
5) With the harddrives so cheap nowadays, does it really make sense to use an old hdd? They have a finite life time, and the older the drive, the more chances are of it failing, and you losing your data. Maybe it would make more sense to buy a new ATA drive and use it instead?
Good luck, and don't forget to come back with a testimonial if helped :)
Posted on Dec 13, 2009
bronk50
  • 27725 Answers
SOURCE: hi i am instullaing a
cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need hope this helps also you might http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Behind a slick interface, this program backs up all your PC's drivers in case you mess up something fierce. From registration to implementation, DriverMax works fast, runs smooth, and does even more than mere backing up.
When you run the app, it asks you if you'd like to run the trial version or apply for a registration key. The key is free, though, requiring only an e-mail address and your name. Once you've entered the key, the program interface appears, with slick button navigation: Driver Operations, Updates and Identification, and Popular Hardware. Mousing over one reveals more choices, so you can export your drivers, import drivers, or view an installed drivers report.
Updates lets you update both the DriverMax software and the drivers themselves, although as of this writing there is a warning label on the DriverMax Web site that downloads are not currently functioning. The program can also identify unknown hardware and point you in the direction of popular hardware options, pointing users to a compilation of statistics about different video cards and processors.
The strongest features, though, relate to driver backup and reinstalls. They function smoothly, offering users the option to back up all drivers or compile a customized list. Reinstalling an "accidentally" deleted driver was as pain-free as could be. As of the version 4.4 update, the DriverMax Agent, which automatically scans for driver updates, works in Windows XP and Windows Vista 32-bit, but not 64-bit. This is a great utility tool that should appeal to newbies, advanced hackers, and everybody in between. Hope this helps
cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category, sub category, price from the category drop down list select drivers them from the price drop down list select free or which ever applies to your need hope this helps dont forget to vote
http://www.majorgeeks.com/.Net_Version_Checker_d6433.html Shows details of all the versions and service packs of .Net frameworks installed on your machine.
http://www.majorgeeks.com/AMD_Driver_Pack_d5098.html
Drivers for AMD motherboards with 751\761\762 bus controllers.
http://www.majorgeeks.com/ATI_Catalyst_for_Windows_7Vista_d5503.html This unified driver has been further enhanced to provide the highest level of power, performance, and reliability. The ATI CATALYST software suite is the ultimate in performance and stability.
http://www.majorgeeks.com/Bluetooth_Driver_Installer_d6752.html
This small freeware utility will try to install generic Microsoft driver for your bluetooth adapter. The program is based on a widely known method of patching %WinDir%\inf\bth.inf file.
http://majorgeeks.com/download.php?det=6171
Driver Sweeper keeps your PC stable and fast with advanced driver removal that ensures the maximal performance of your PC. Driver Sweeper avoids driver conflicts and system failures by removing all previous driver entries. Combined with additional features such as backups and a desktop icon manager, Driver Sweeper offers a complete solution to all your driver needs.
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
hope this helps
Posted on Mar 26, 2011
I need firmware for quantum fireball lct 15. thenk you
I have a firmware for fireball lct15 a01.0f00. If you need it give me your e-mail adress and i'll send it to you.
Mar 24, 2011 | Quantum Fireball Lct15 7.5 GB ATA-66 Hard...
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax Plus 9
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Hard disk not recognized
found the solution inside Dell web page - jumper position shown graphically - Thank you, anyway.
Jan 07, 2010 | Quantum Fireball Lct20 (QML20000LD-A) 20...
main Dell Optiplex
Slave (cable select)
Quantum Fireball
once you have installed them physically into your comptuer like that, start it up.
Format Quantum Fireball
Now you still have windows xp, and you have a clean 2nd hard drive.
You do not need to install windows xp on the 2nd drive
Quantum Fireball .
Dec 13, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Oct 22, 2009 | Quantum Fireball Plus AS (QMP20000AS-A)...
Just transfered hard drive to another computer - in setup- need to know capacity, cylinders, heads, sectors
The specs are:
Capacity (unformatted/formatted):
20.00 GB / 15.02 GB
Cylinders: 16,383
Heads: 16
Sectors: 63
Here is a PDF w/specs
Fireball lct15
(http://www.dll.com.mx/biblioteca/HDD/Quantum/Fireball%20LCT15.pdf)
Hope this helps!
Sep 11, 2009 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Jumper go`s in what line.if power out let it on my right handside
moz-screenshot.jpgHere is a picture I found that shows the jumper settings for:
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
http://www.tacktech.com/images/articles/379/mxo_ata_jumpers_2.png
Apr 26, 2009 | Quantum Fireball (LM20A011) 20.5 GB Hard...
Problem putting a 30 gig quantum lct 15 3.5"series as a slave
Did you switch the jumper config back to Master or CableSelect before trying to install them as a single drive? Also check the Maxtor website, (they owned Quantum too), for the correct jumper settings. Some of these drives (like the Quantum Fireball lct series) need TWO jumpers not just one.That was the trick that fixed mine from not being recognized by the Bios or the Windows setup disk....I got it used with only a single jumper, but it needed two to put it Cable Select mode.
Apr 07, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Drivers download
Dec 07, 2008 | Quantum Fireball Plus AS (QMP30000AS-A) 30...
Quantum Fireball Plus 10.1 GB
Look halfway down the page for Quantum Fireball LM.....
http://www.tacktech.com/display.cfm?ttid=379
You will find the jumper settings there.
Nov 25, 2008 | Quantum Fireball Plus LM 10.2 GB ATA-66...
Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n CX13A011 13 GB Hard Drive Logo
460 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
