Question about Acer Aspire One D150-1587 Netbook
My computer will not start up the fan clicks on forr about two seconds then stops flasshing the bios did not work
    President:
  • 1,187 Answers
Remove the battery andturn on the laptop using the AC power adapter.
It should start up ok... After it starts, put the battery back into the laptop and let it charge for a few hours.
Posted on Nov 13, 2009
Why did Fan stopped working?
It is unfortunate that the Fan has stopped working but please let me know if the computer is working fine. You may use the below link and update the BIOS to the latest one:
http://dell.to/1lWy5O1
Input the system service tag, click drivers & downloads, select & download the latest BIOS under BIOS tab.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Jun 25, 2014 | Dell Inspiron Computers & Internet
Updated Bios for Toshiba Satelite C55-A5286 and now computer keeps crashing
Sounds like it may be related to the installation of the new vid card. I'd take it back to the shop where I had it worked on and tell them the problems your experiencing and tell them they screwed it up and you want it fixed-pro bono!
Jul 11, 2017 | Toshiba SatelliteR C55-A5286 Laptop...
Screen not displaying. and fun starts and stops, remains stand by when restarted the fun runs and stops stand by.
hello there,
I got the same problem but it came gradually...
In fact for a full month when I first boot the computer, the fans runs, no extra beeps, the light blinked correctly but no bios at the screeen. I remarked also that the fans run full speed doing a lot of noise. Then I stopped the computer and wait 2 minutes and then it always works correclty at the second boot with the bios screen appearing. Also, the fan calm down after 1 second with less noise. So when I start the computer and hear that the fan calm down with less noise after 1 second, I know that the computer will boot correctly. That happens always at the second try after waiting 2 minutes. But since yesterday, the fans never calm down and the noise still remains high with no Bios at the screen. I'm suspecting the Power Supply...
i hope my i dea can help you.
Sep 02, 2011 | Dell Inspiron 1545 Notebook
Power On, Fans start but stop in few seconds and that's all
May be there is a problem in the windows, but suppose it is not booting at all.
First Check once more your boot options from bios menu
Second If it still the same thing, extract your battery out of your laptop for 12 min, then try to power up your laptop pluging in your power cable(don't use your battery)
Third If it still not working, there must be a problem in your cooling fan, so check it, also check your motherboard & your graphics card (Most of this problems happens due to a problem in the computer cooling system in motherboard & graphics card)
Hope it works for you Christos
Jan 30, 2010 | Toshiba Satellite P200-0TD00Y Notebook
Kenmore he2 dryer when pushing the start button, it will click and then the digital readout flasshes an F then it flashes 26 got any ideas?
PRESS STOP OPEN DOOR PRESS BLACK BUTTON MIDDLE OF MACHINE ABOVE THE LACTH U WILL HEAR A CLICK THAT RESOLVE THE SITUATION
Aug 19, 2009 | Dryers
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Starting proplem
The one beep is normal . If the fan is not working on the CPU , replace the fan or oil it The CPU can go only a second or so without the fan working. Some models(BIOS )will not allow the computer to start if the fan is not working. Start there.Check out the link below:
http://www.computerhope.com/beep.htm
Jan 19, 2009 | Compaq Presario SR1000T (568657) PC...
Gateway 675 fan problem
Check the BIOS in the laptop. The CPU fan and unit fan is controlled by temp. U can set it for a lower temp. The Bios is accessed when U boot up... F2 usually, There should be a 5 to 15 second screen telling u what to press to get there.
Good luck
Mar 07, 2008 | Computers & Internet
Sony Vaio pcv-rs 312v
check whether your SMPS fan is running the back side of the cabinetand also the cpu fan if you can open the system case. if the both fan is running fine then rmove the CMOS battery and start the computer after 2 or 3 sec the cpu fan will stop that means BIOS is cleared reinsert the battery and boot the system go to BIOS and go to load default setting and enter(press DEL or f2 to enter BIOS) after that press f8 and go to safe mode (not work with win98)it will take some time,after getting in to the OS scan your computer for virus with best and latest updated ANTI VIRUS. let me know whether it is working ot not. if not working kindly let me know what the exact problem is write all the process you follow to start your PC reply me soon
Oct 07, 2007 | Sony VAIO PCV-RS312V PC Desktop
Computer wont boot
This is a memory detection fault. Remove and reseat memory, try one at a time. If no joy then reset the bios at the JBAT1 terminal put jumper from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. Restart your pc hopefully then set time and date in standard bios settings and check hard disk is recognised.
Jan 24, 2007 | Abit A17 Guru Motherboard
Acer Aspire One D150-1587 Netbook Logo
190 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
