Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Paper jam it says theres a paper jam its just a little piece of paper and i cant get it out how can i take the cover off to get the paper
    Problem Solver:
  • 7 Answers
You should take it to your local service agent as if you remove the cover your self then you will loose you warranty, also if the paper jam is in the paper feed then use a lamanated peace of cardbored
Posted on Nov 13, 2009
Printer says there is a paper jam but there is not.
Please double check your printer for paper. Just a little piece of paper left in the printer rollers or out tray will not let the printer operate property.
Oct 01, 2009 | HP PSC 1210 All-In-One InkJet Printer
I have unjammed printer - still says that there is a paper jam
If you have removed all drums, fuser, transport belt, cassette and duplexer if fitted and ensured there is no paper, and turned off and on printer whilst disconnected from pc, and it still instantly comes up with a jam, then I'll tell you where it is... open front cover, in center,front.. there is a cover a little bigger than match box, it clicks off, under here is your jammed sheet , people tend to just rip out the jam, and leave behind a small section of the paper, that you cant see, unless you look very carefully or remove little cover to expose it.
Jan 13, 2009 | OKI C5100n Laser Printer
Error paper jam
ellow bkadam,
there something little piece of paper stuck at you fuser there.that why appear paper jammed...try to open u fuser cover...maybe it can help
Nov 07, 2008 | HP LaserJet 2840 All-In-One Printer
Paper jam, open back cover, then remove paper jam
Ther is some tiny little paper piece left in the machine! You will find it at the left hand side near the gear wheels ;-)
Jun 13, 2008 | Brother MFC-5460CN All-In-One InkJet...
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Brother MFC 845 CW Paper Jam
which two digit error code does the machine display despite paperjam?
Mar 25, 2008 | Brother MFC-845CW multi-function...
Canon PIXMA MP160 showing paper jam, but none
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Feb 24, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam
please give more info. do you see the paper? does it say paper jam when just turned on? does it feed then jam?
Nov 08, 2007 | HP LaserJet 1320n Printer
Print cartridge is stalled
this will need to be taken to the service center for servicing.NO easy aasy to solve this problem
Jun 08, 2007 | HP PSC 2410 All-In-One InkJet Printer
OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
I too kept getting the front cover paper jam despite followings Oki's paper jam removal instructions and blowing out the printer with compressed air.
In my case, the paper drawer was the problem.  When you pull out the drawer there is a spring loaded piece of white plastic at the very front of the drawer.  In the center of that is a gray rubber strip.  That strip had come loose in the center and bowed out, preventing paper from exiting the paper drawer.  I manually removed the strip, clipped off a little piece from one end so that it fit back in the recessed cavity on the white plastic piece and glued it back down.
This should be applicable to all Oki c5xxx color LED printers.
Dec 03, 2006 | OKI C5100n Laser Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
55 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
