Question about Zenith R56W36 56" Rear Projection Television
Have sound no picture any ideals? - Zenith R56W36 56" Rear Projection Television
    Problem Solver:
  • 9 Answers
Sounds like you have a bulb issue you should contact zenith and they will sell you the bulb and ship it out to you you might need a technician to install but i doubt you cant do it yourself
Posted on Nov 13, 2009
My Zeinth big screen tv has a line on the screen going left to right, and has no sound? What can be the problem?
Posted on Dec 16, 2009
My netflix has a lag
This is due to a slow broadband speed. Ideally you need at a minimum 2.5Gbs.
Mar 26, 2014 | Netflix
How do you find the white balance on this camera?
This camera does not have a customizable white balance. It does have some presets -- they are:
  • Auto (default)-automatically corrects white
balance. Ideal for general picture taking.
  • Daylight-for pictures in natural lighting.
  • Tungsten-corrects the orange cast of household
light bulbs. Ideal for indoor pictures under tungsten or
halogen lighting without flash.
  • Fluorescent-corrects the green cast of fluorescent
lighting. Ideal for indoor pictures under fluorescent
To access them, press the [Menu] button and look for White Balance -- the icon is a Sun and Light Bulb symbol.
Oct 28, 2013 | Kodak EasyShare Z760 Digital Camera
Our tv is about 3 years old. We are a Time Warner cable customer. About 2 months ago we started to notice that the picture took a ong time to appear after turning on the set. The sound played for about...
I'm sure this is fairly easy to repair. It sounds likely to be a power supply problem, possibly due to bad capacitors. Your original symptoms of no picture were likely to be the backlight controller not having sufficient power to operate correctly. Ideally you should have it looked at and repaired then because leaving it to get worse may well have caused additional component failure. Get it checked by a reputable TV repair engineer.
Feb 27, 2011 | LG 32LC7D Television
I have a Denon AVR 1705 and can get a tv picture and no sound or sound with no picture. Is there a setting or selection that I am missing to have both.
Sounds like the sound inputs have been reassigned to another input-
You'll ideally need the instructions to give a fuller idea of how you adjust these and all the options it gives you
Sep 03, 2010 | Denon AVR-1705 Receiver
I cant get into my camera function
From the BlackBerry Curve 8520 Home screen, press the Camera key on the side of the phone > Press the Menu key > Scroll to and select Options > Scroll to and select the desired setting: * White Balance : This setting changes the contrast of the pictures taken to optimal for the listed conditions:
o Automatic: The device automatically adjusts the contrast for each picture.
o Sunny: Ideal for outdoor pictures on a sunny day.
o Cloudy: Ideal for outdoor pictures on a cloudy day.
o Night: Ideal for pictures in low-light conditions.
o Incandescent: Ideal for indoor pictures with incandescent lighting.
o Fluorescent: Ideal for indoor pictures with fluorescent lighting.
* Picture Size: To change the size of pictures taken. Larger pictures require more storage space.
o Large (1600 x 1200)
o Medium (1024 x 768)
o Small (640 x 480)
* Picture Quality: To change the quality of pictures taken. Finer quality pictures require more storage space.
o Superfine: Best quality
o Fine: Medium quality
o Normal: Lowest quality
* Color Effect
o Normal: To take color pictures.
o Black & White: To take black and white pictures.
o Sepia: To take pictures with a sepia tint for an old-fashioned look.
* Store Pictures: This gives you the option to store pictures you take to either the device memory or the media card, if available.
* Folder: To change the default storage location for pictures taken with the camera.
After you adjust your BlackBerry Curve camera settings, pess the Menu key and select save.
Nov 19, 2009 | RIM BlackBerry Curve 8520 Smartphone
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Connecting older tv to dvd/vhs and hd set top box
Radio Shack for a Y splitter usually around 4 dollars. You will need one for each line IE: yellow for picture red and white for sound for a total of three Y splitters. In your case you only have mono sound so will only need Two Y splitters.
Ps. dont forget to rate my answer if you would.
Dec 27, 2008 | Televison & Video
About camera shutter sound
HI Maddy, You can turn off the shutter sounds in teh settings menu. This will turn off the sound altogether so not ideal but at least a work around.
Oct 28, 2008 | Sony Ericsson K750i Cellular Phone
TV has audio sound and no picture
major repair; requires 16 pin ic
Apr 19, 2008 | Televison & Video
No picture or sound
ether the color will is bad or the DMD bord is having Problems try to clean it I tell how in my ether post.
Dec 21, 2007 | Samsung HLN5065W 50" Rear Projection...
Zenith R56W36 56" Rear Projection Television Logo
319 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
