Question about Acer Aspire One Netbook 8.9" Notebook
How to cable boot acer one w/ dell lat need to replace boot mgmt and upgrade softwafe
How do i remove the palm rest off this laptop??
Shaun Miyen,
You can click the link below to download the users manual for the Latitude 7240. The manual provides instructions for removing/replacing parts within your computer.
http://dell.to/1G2K2Ij
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Sep 21, 2015 | Dell LAT 7240 I7-4600U 2.1G 8GB 256GB...
I have a dell laptop lat d610 have not used for while now on boot up " machine's configuration has expired please contact safeboot administrator
Will it boot into win normally after displaying this pre-boot error? If you have mcafee on it you may be able to solve the per boot error message via this link. https://kc.mcafee.com/corporate/index?page=content&id=KB53773 Let us know if anything changes.
Dec 09, 2013 | Dell Latitude D 600/610
Dell Lat d620 duo: ran a full system scan yesterday as I normally do for maintenance and got the BSOD. Message: page fault in nonpaged area. Tried all options to reboot, always eventually gets to BSOD and...
Take out the memory and replace with the old one.
If you have a 32 bit Windows and have more that 4GB RAM then you need to upgrade to 64 BIT.
This is the RAM you need:
Standard Memory : 256MB (Removable) Maximum Memory : 2GB Total Memory Slots : 2 Memory Type : DDR2 533MHz (PC2-4200) 200-PIN SODIMM Notes :
http://orcamemory.com/asp/prodtype.asp?prodtype=11759&ft=m
Jan 06, 2010 | Dell Latitude D620 Notebook
I want to now which ram is used for dell latitude 640, latitude 520, latitude 430, latitude 420 and inspiron 2200 is it ddr2 or ddr1 and max capicity for upgrade
Here are the max memory and speeds:
Lat C640 is Max 512M per stick DDR-266 (PC2100) or DDR333 ( PC2700 ) for a total of 1024 Meg
Lat D520 is either 2 or 4 Meg total. DDR2-667 ( PC2-5300 )
Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.Maximum memory for systems with the Intel 945GM chipset is 4096MB, maximum memory with the Intel 940GML chipset is 2048MB
Lat D430 has only slot with a Max of 1 Meg. You can use DDR2-667 (PC2-5300)  or DDR2-533 (PC2-4200)
Lat D420 is a max of  1.5G    . Use 1GB DDR2-533 (PC2-4200)
Inspiron 2200 is one slot with a max of 1280 Meg. recomended is 1GB DDR-333 (PC2700)
Here is a link to find almost any memory you need:
http://www.crucial.com/index.aspx
NOTE:
When mixed speeds in the same PC, the memory will run at the slowest speed installed or the highest speed allowed by your system, whichever is slower.
Good Luck
Dec 17, 2009 | Dell Latitude C640 Notebook
Laptop won't boot into Windows XP
Did you do an upgrade or new install? Did you check the system requirements first to see if you could upgrade to Vista? This could all play a part in why it does not boot up. I suggest you reinstall windows XP again.
Jul 04, 2009 | Acer Aspire 5610-4648 Notebook
Acer eLock Mgmt has my devices locked out.
This is a Quoye straight from the Acer knowledge base for the elock software...
If you forget your password, you will need to
take your notebook PC to an Acer Customer Service Center.
Apr 01, 2009 | Acer Aspire 4520-5582 Notebook
Strange video issue. help please.
This sounds like a damaged motherboard. I would check with Dell's chat support, they can direct you to more troubleshooting resources and maybe even offer genuine repair parts. I have used them quite a bit, and if you can convince them you have an A+ cert, most of the time you can skip a lot of the BS steps that never work or do not help.
here's thier link:
http://support.dell.com/support/topics/global.aspx/support/chat/hardware_chat?c=us&cs=19&l=en&s=dhs&redirect=2
Mar 17, 2009 | Dell Latitude C640 Notebook
Screen wont show boot screen
fo to bios options by pressing f2 or del soon the power button is released. thre u can find an option to enable silent boot . turn it on
Dec 08, 2007 | Dell Latitude C400 Notebook
Get on the internet
: just activate your laptop wireless connection by putting on with the button or manually by in network properties then put the security code of your wireless router when he ask you.
Nov 28, 2007 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
