Question about Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
I have a Uniden 5.8GHz DSS8955+1 and it's connected to my phone and fax. The problem is: everytime the fax rings, the answer machine works as it works when is a phone call. How do I set up the machine not to work when the fax is calling?
    Sergeant:
  • 267 Answers
Set your answering machine to pick up after four ringsI have a Uniden 5.8GHz DSS8955+1 and it's - 2.gif . This will give the fax machine enough time to take the call if it senses that it's an incoming fax. Setting the answering machine to pick up after four rings would give the fax machine enough time to accept the fax.
hope this was helpful .
Posted on Nov 13, 2009
Dx-800 wont work with answering machine. Tried all the fax settings to use with a tam. Tam picks up line then dx-800 drops out everytime.
Set the answering machine to answer on 4 rings and the fax to answer on 6 rings.Do this with answering machine menu.
May 15, 2011 | Panasonic Panafax DX-800 Plain Paper Laser...
How do I turn off my ringer on my Uniden 5,8ghz expandable cordless phone system
Since you declined to specify the model of your Uniden phone, I can only direct you to select it from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl
to download a copy of the manual.
Jan 08, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
IT WILL RING BUT GOES TO ANSWERING MACHINE DOES NOT RECEIVE FAX
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
Answering machine rings
you can set them for 2 or 4 rings.
May 30, 2009 | Uniden 5.8GHz Dual Cordless Phone
Answering system and fax do not operate together
You want to change a timer on a fax machine to ring more times before it picks up.
Cheers
Mar 25, 2009 | Uniden Lands Phones
Not receiving faxes
make sure your answering machine is plugged in to the "EXT" jack on fax machine, and your main line plugged into "line". try setting fax rings to 1 or 2. set your answering machine to 4. your fax should intercept the call and if it hears the fax tone, will receive the fax. if it doesn't hear the fax tone, it should forward the call to your answering m/c.
hth,
razors
Jan 03, 2009 | Brother IntelliFax-2820 Laser Fax
Fax answer phone line
You set the machine up in the answer/fax mode, when a fax is coming in you have to press 9 on the phone to make it receive the fax if you pick up the receiver when it is a fax call.
You can also change the number of rings to answer a fax, I think the max is 7 rings.
Dec 20, 2008 | Xerox WorkCentre Pro 412 All-In-One Laser...
My phone does not ring when a call is received
I've found this to be a problem with regular phone lines (POTS) and Uniden phones. Uniden phones do not seem to support 90v @ 20hz ringing voltage / frequency. They work fine in every aspect except for ringing. These phones do work well with voip, where you aren't connected to the telephone company and have calls routed over the internet. The boxes that handle the voip calls generally produce less than 90v and work well w/ Uniden phones.
Dec 18, 2008 | Uniden TRU8885 Digital Answering Machine
DXA18580 series
Increase the # of rings before the fax picks up so that it's greater than the # of rings before the answering machine picks up. When you're expecting a fax, turn off the answering machine.
Syskiyou
Jul 26, 2008 | Uniden Cordless phone EXS9950
Answering machine turns on and I can't receive faxes.
Why don't you consider a separate Phone/Fax switch. It will answer first ring and detect a fax and then ring the fax/printer you can set that to one ring as well, otherwise it ring the answering machine that is plugged into that and you can set that to answer on 3 or 4 rings. Then you have time to pickup phone if you are available.
Thanks what I do. The boxes are about $30 They are fairly cheap.
Nov 24, 2007 | HP LaserJet 3055 All-In-One Printer
Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
213 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
