Question about Motorola Mobility RAZR V3
I have some flecks/spotting on the internal side of my screen. How can clear them off?
Black spot appeared on the screen on bottom left side how to clear it
A large black spot usually means the LCD screen is damaged. It may have fine cracks around the black spot. In this case the LCD screen needs to be replaced.
A replacement screen maybe available for your laptop from this WEB site.
LCD screens and Inverters www.lcdparts.net
Feb 12, 2013 | Lenovo Computers & Internet
Hi, power was lost in the house about 4 weeks ago for 11 hours, the fleck 5600 has not done a regeneration cycle since. I check the power to it. Not using any salt. System is around 1 year old. Any...
On the Fleck 5600 the timer motor also serves as the drive motor. It is on the back side of the control in the upper left hand corner. Reset the time of day and see if it keeps proper time. If not the timer motor needs to be replaced. If the control is an sxt model the circuit board may be bad from a power surge.
RJ
Sep 18, 2011 | NRS Fleck 5600 - 64,000 Grain Timer Water...
I have little spots all over the screen display, i believe to be caused by dust in the lens assembly. could that be the problem? i see a lot of dust behind the glass... how do i clean it?
If there is dirt or other deposits on the LCD panels they are usually most visible at the extremes of focus. They will be blobby. You may also be seeing dead pixels which are clearly visible when in focus.The lens assembly itself will be sealed and is unlikely to be the problem, don't worry about flecks of dust in the lens area. You can clean the external lens with a soft cloth, much like a camera lens.
Projector internal optics are non-user servicable. If you can't live with the spots it will need to go to an approved center for cleaning / or repair. You should be able to find out where via this page
Feb 14, 2011 | Sharp XG-E3500 Multimedia Projector
I have a Mitsubishi WD-57733 television. I have noticed that there are black and white light flecks on my screen. For example when the television is turning off and the screen is black it looks like stars...
your problem comes from the dmd chip, try to examine it using a magnifying glass and you will see all the white spot on it.i already experience that, replacing the dmd chip solve the problem.check this site (www.tvlampforless.com)
Oct 27, 2010 | Mitsubishi WD-57733 57" HDTV
Our Kenmore 665 was leaving white flecks on dishes and glasses
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 10, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Insignia ns-lcd27fs getting green flecks on screen
is a flat LCD internal flat cable problems, or control board defective, send to repair.
Dec 28, 2009 | Insignia IS-LCDTV32 32 in. Television
Flecks or spots of something on cloths after washing
Main tub bearing is likely failed. It is a big job.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | KitchenAid Washing Machines
Dark screen on TV
This sounds like a speaker got too close to the TV.
Degauss is built into many tv's check for it in the menu.
Otherwise, yes a TV shop or yourself will need to degauss the TV.
May 14, 2008 | Televison & Video
YELLOW SPOT ON SCREEN
There may be a dust fleck on one of the LCD screens inside your projector. I had a similar problem and managed to clean it. But it requires you to dissassemble the entire projector !!!. If you are not technical, don't do this yourself. !!!
Feb 16, 2008 | Sony VPL CS5 Multimedia Projector
Motorola Mobility RAZR V3 Logo
24 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
