Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Colour selection Scan settings
How do I make the black colour selection the default setting for every scan?
  • 167 Answers
Set up the copier to the settings you wish to use. In the Utility menue there is an area called "Default Setting" (?) selecting this will give you the current settings as default, here you can also reset to factory defaults
Posted on Jan 08, 2008
  • Kevin Hayes
    Kevin Hayes Jan 09, 2008
    OOPS! Gave you the wrong information there... Just did it on My KM as follows.
    Push the Scan button so the scan option screen appears, under scan settings, set it to the default you wish, coliur, file type, resolution, etc.
    Then on the panel, push the "Utility" button, in that screen select "User Settings" and from there select "Intial settings"
    At this point you will have 2 options select "current setting". This is also where you set it back to factory defaults.
    The same method is used for copying, just begin at the copy screen.
Color image scan produces black and white pdf
This is purely down to the scanner settings. In the scan settings, choose the resolution and if to scan in monochrome (or B&W) or colour. SAVE the settings. Try a rescan and you should find that will work.
Nov 26, 2013 | HP Officejet Pro 8600
Will not scan due to no colour ink. do not want to
hi,
As you dont want to use the colour ink,When you give the print command you wil get the print properties page ,In that you can select black and white so that you wil not use up the colour catridge. It uses black catridge only.
thanx
Jul 21, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
Default Setting Change?
you need to set you initial copy screen up as auto colour select then go into copy settings and store them like that.
Jun 02, 2009 | Office Equipment & Supplies
My Lexmark P4350 printer is not scanning images to my computer?
To scan a document, please follow the steps given below:
1. Go to "Start," "All Programs," Lexmark 4300 Series, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
May 11, 2009 | Lexmark P4350 All-In-One InkJet Printer
Difference between ''Auot Color'' and ''Full Color Mode
Most Colour machines have three settings.
Auto Colour, Machine will determine if the original is Colour or Black and White from its scan. Then print in the format that best suits the original.
Full Colour, Machine will copy in full Colour regardless of Original type.
Black and White, Machine will copy or scan in B & W regardless of original type.
Hope this is of some help.
Ed
Apr 17, 2009 | Kyocera Office Equipment & Supplies
Not able to scan in colour....help
the canon ir3300 have only black & white scanner not a colour scanner, if u want to scan colour photo then go for ir 6600 or ir105 model
thks
Mar 06, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
Scan pictures in colour from hp1200 go to photo imaginig not E/mail----scan coloured prints from scan documents to E-mail finish in black/white
NEED TO GO TO PROPERTIES of printer and do a DEFAULT ,
to bring all settings at factory sets, hope this helps AJ
May 14, 2008 | Office Equipment & Supplies
Bizhub C250
In the Utility Menu you can set the default settings for most functions. Set the copier to the state you wish it to be in. Under the utility menu there is a default setting button. This will allow you to set the current state to the default as well as reset to factory default.
Feb 27, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
355 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
