Question about Freezers
Is manual freezer suppost to be warm on both sides , and it seems to run a lot shut off 5 runs again
  • 4,066 Answers
If you have a condenser fan, it's probably not running. It's the fan underneath near the compressor and blows the heat off the condenser coils. It should run when the compressor runs. It should spin freely when you turn it and if there is voltage to the fan plug it should be running.
Posted on Nov 13, 2009
Testimonial: "would that cause freezer to run for long pereiods before shutting off?thanks ill see if i can check fan .thank you "
Kenmore upright freezer does not shut off until door is opened. freezer seems to work well.
Going by the service manual it seems that everything is fine. The fan is supposed to run while the door is shut and the compressor is supposed to run 12 hours and then a 30 min defrost cycle comes on then the cycle starts over again. I am posting the service manual, parts and wiring diagram for you to view if you so choose. https://files.acrobat.com/a/preview/8a6d6ca4-04b6-4cfa-b435-3980042b3ad3
https://files.acrobat.com/a/preview/6d7f8a46-0daf-4e01-aa54-01f306301f31
https://files.acrobat.com/a/preview/12246a57-0a63-4d66-b3f3-7f7b67536da6
May 31, 2016 | Kenmore Freezers
Why are the sides of my upright freezer hot and the compressor very hot
Good Afternoon Friend,
I understand the sides of your Frigidaire freezer are hot and the compressor is very hot. I also see that the drain plug was frozen and the coils had lots of frost, which you defrosted and your freezer began running again. It looks like your freezer quit again and started up, leaving everything hot. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose and determine what exactly is causing your appliance to be hot. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire Freezers
Greetings: I have a 4-5 yr old Whirlpool up-right
lucky to get five years out of any white good
time to do the math
replacement cost of failed components
verses
benefits of a new up-right Freezer
Feb 28, 2017 | Whirlpool Freezers
Is it normal for the freezer to go off periodically? It just seems to stop running and later it will start running again. I've had this freezer for 5 years and don't ever remeber this happening before.
By stop running do you mean become quiet or do you mean quit cooling and unthaw all the food?
If you mean turn off and still be cold then that is normal.
If you mean turn off and warm up that is not normal
Apr 22, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer runs for 2 seconds then stops, and runs this cycle.
Good day,
The shut off is due to the protective overload mounted on the side of the compressor to shut it down, if it can't start.
On the side of the compressor is a cover box that contains the overload device, a start relay, and on some models, a start/run capacitor.
These items can to a degree tested with an ohm meter, but it is wiser to take them to an appliance parts house for testing.
If any are found defective, replace them. If not, the compressor has failed internally and needs to be replaced. Close to $400.00 if not more.
Feb 06, 2010 | Freezers
Refrigerator just stopped cooling all of a sudden. neither side is cooling and the freezer side is barely freezing all of food is going to waste help please
is the compressor running ? if yes feel the cooper tubes around , the tiniest one is suppost to be hot if is not hot u have a leak call a tech . if it is hot open the freezer and take the back cover inside of the freezer if the coil is totaly covered with ice you have a defrost problem , check the timer , bimetal and heater
Jun 19, 2009 | Freezers
Kenmore Upright Freezer compressor running 6 seconds every minute
Usually the compressor runs pretty warm anyway. However if you think it's too hot I would start with the condenser coils located either under the unit or on occasion they are located on the back. The air flow across these coils as well as the airflow around the compressor must be maintained. I forgot to ask if the condenser fan is running. Check and make sure that the Fan is running and the air flow is good. Also, When you transported the unit did you move it standing vertically like it normally stands or did you lay it on its side. If you transported the unit on its side you must wait a minimum of 24 to 48 hours prior to start up or the unit could be ruined permanently. The refrigerant has to be utilized through the compressor as a gas. If the unit is on its side liquid refrigerant could be introduced into the compressor and can cause permanent damage. If this is the case I recommend that you turn the unit off at once and wait the 36 hours for the Refrigerant to settle then try it again. This transportation rule applies for any appliance That uses refrigerant, Air Conditioners etc. These units are not that hard to diagnose. The only other item that is usually a problem is the defrost timer. It is not very expensive and can also cause some of the same symptoms that you are eluding to. The defrost timer allows the freezer to periodically shut down to prevent the buildup of frost or ice on he evaporator coils and on the inside the unit. If it is defective, then the unit will either run all the time and cause the evaporator coils to freeze up or will not allow the compressor to switch on and it will not freeze like it should.
Nov 12, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Dead Upright Frigidaire Freezer
YOU MOST LIKELY HAVE A FREON LEAK AND RUNNING THE FREEZER WITHOUT FREON IN IT WILL KILL THE COMPRESSOR UNLESS YOU UNPLUG IT AND GET IT FIXED,THE COILS ON MOST FREEZERS ARE IN THE SIDE WALLS SO YOU DON'T HAVE TO CLEAN THEM LIKE ON YOUR FRIG.HOPE THIS HELPS-MIKE
Jun 16, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Sides of freezer extremely hot
if there is air getting into the freezer because the door is not sealing properly the unit will run because it is sensing it is not cold enough inside. your unit releses the heat from the refrigerant through copper tubing that runs through the cabinet, and thats why it is hot. you need to level the unit make sure the door is sealing on the top bottom and both sides ansd then the freezer will work properly and be able to shut off after it has come down to the proper temp.
Aug 05, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
