Question about GE USB Retractable Number Pad HO98462
How to instal and use this ge 98757 number pad?
Set clock on ge profile gas range
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Nov 06, 2016 | GE Kitchen Ranges
Ge profile gas range, no clock pad...how do i set clock. It says hold 3 seconds. What do i hold?
You didn't give a model number, but try the following:
For an electronic clock:
Touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. (Taken from the GE website)
Why are GE Profile JT930 touch pad numbers not working?
Seems problem with the touch pad. Try replacing the same.
Aug 16, 2014 | GE Appliances 30" Trivection Built-in...
Ge true temp cooking range number pad does not work
Turn off your house breaker for five minutes then back on, if this does not correct the problem you will need a service man.
Apr 05, 2014 | GE Microwave Ovens
Ge profile oven key pad
is this the model number P2S975SEPSS.?
Sep 30, 2013 | GE Profile P2S975SEPSS 30" Duel Fuel...
Mac does not recognize my retractable number pad
Maybe it is not recognized by the MAC operating system. Just download driver associated with MAC operating system and install it. Some hardware need software driver to be able to work. Some just plug and play.
Dec 29, 2010 | GE USB Retractable Number Pad HO98462
Cannaot install the dvice
Is the number pad supported by the OS? Check here please: http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Thank you for your interest in FixYa.com
Sep 27, 2010 | GE USB Retractable Number Pad HO98462
GE Retractable USB Number Pad doesn't "Plug n Play"
I would take it back if it did not come with a driver. any hardware device is useless if the operating system does not know how to operate it, and if XP has no native driver support for it, then it will need a driver on a disc, and if there was no driver software for the device, then the device is of no use to you. But, I would look for any "number pad" driver and give it a try.
May 26, 2009 | Computers & Internet
Claibrating the temperature of a GE gas oven
5 degree increments from factory setting
1 is +5
2+10
and so on
Apr 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Cant figure out how to stop the timer before it goes out, or runs out of time
You should be able to hit the Stop pad, but you can download GE owner's manuals and installation instructions here.
If some of the pads on the keypad are not working, you may have a failed keypad, which can be replaced.
If so, please reply back with your model number and let us know.
Sep 28, 2008 | GE XL1800 1100 Watts Microwave Oven
GE USB Retractable Number Pad HO98462 Logo
334 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
