Question about HP Deskjet F4180 All-in-One InkJet Printer
My hp printer doesnot work what is the procedure for that
  • HP Master
  • 4,924 Answers
Turn it off...and when you turn it on ...keep the button for on /reset pressed fro about 10 seconds...it suppose to reset it ..and it might work .....also it might be an issue of driver ...so ..reinstall the driver clean ..and gave it a try ..
Posted on Nov 13, 2009
My printer won't print yellow even though the
uninstall and reinstall the printer
and make sure that you download the drivers from HP.com
it it doesnot work it is an hardware issue that is the issue is with the printer
Mar 19, 2010 | HP Photosmart C8180 InkJet Printer
Everything works fine except when copying. Printing overwrites in duplicate. Have cleaned and realigned cartridge. Can you offer any advice? Thanks Bernie
try to scan and see what happens
if you are able to scan then uninstall and reinstall the printer software frm HP.com
if that doesnot work it is an issue with the printer
Mar 12, 2010 | HP Officejet 4355 All-In-One InkJet...
The paper comes out "crunched" on one side, i.e. it has creases in it
it is a typical harware issue
i suggest try a power reset
by taking out all the cables and leave the printer for 3 min and power it on again and if that doesnot help try taking out the tonner and check for any physical paper jam it that doesnot work then am afraid it time u get a new printer
Feb 23, 2010 | HP LaserJet 1012 Printer
Error 0X61011BE9 ON HP PHOTOSMART D5460
try connecting the printer directly to wall, if it doesnot reslve the issue than printer needs to be serviced from Authorised Service Provider
Aug 18, 2009 | HP Photosmart D5460 InkJet Printer
My printer is not working
A wire is broken off of the tray 2 lift motor. It can be resoldered.
Jun 13, 2009 | HP LaserJet 4250n Printer
Paper jammed cannot get paper out-
in hp if paper is jammed u just switch it off with the button over the printer not the main plug
the paper just comes out if tat doesnot work u just pull it out nothing wil happen
Mar 17, 2009 | HP PSC 1510 All-In-One InkJet Printer
When i give the command to print , it doesnot
Go to the Control Panel>Printer and Faxes>Double click on "HP Officejet 5610" and check that is any pending jobs or not in queue.
If yes then delete all of them and then give the print command.
If the deleting will not happend then shutdown your pc and on it after 2 min and then try to print.
If this is not helpful then :
1) Check all the cable of printer that it is attached properly or not.
2) Remove the printer driver and restart your machine and than install the fresh copy of your printer driver.
Mar 04, 2009 | HP Officejet 5610 All-In-One InkJet...
Goes offline and if on line doesnot print document
RIGHT CLICK ON PRINTER ICON -- SELECT USE OFFLINE MODE -- HOPE A SOLUTION BRO
Jan 10, 2008 | HP Deskjet D2360 InkJet Printer
Printer doesnot Power On (no power surges either)
In case of Power Failures / Surges.....we should first check if the h/w of the printer has gone Bad... Try the following in the specified order... 1. Unplug the power cable at the back of the printer and replug it and then press the "ON" button on the printer to check if it works else... 2. Unplug the power cable from the surge protector (if you are using one) and replug it and then press "ON" button else just try unplugging from the wall jack and replug the cable (if you are not using a surge). 3. Else , Try a different wall jack 4. You may even try taking the printer to a different room and then check if you get some power. Now if the printer powers up but the "startup cycle" continues...it needs a "semi full reset" to do that-> 5. unplug the power at the back of the printer and 6. press # and "6" at the same time on the front panel 7. while holding these two buttons , replug the power at the back and keep holding till you see "semi full reset" on the screen 8. Now release the buttons and let the reset complete...you may be prompted to enter the language again etc.... Even if this doesnot work...try a "full reset" 9. Which is done by pressing "#" and "9" simultaneously with the same procedure Else the firmware(program inside the printer) has gone bad and may need replacement I got this valuable information from the engineers of ***
Jan 23, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP Deskjet F4180 All-in-One InkJet Printer Logo
402 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
