Question about Cameras
My ex-p700 flash has not been working for a long time, is there a quick check I can do?
  • 561 Answers
1in your settings ensure that flash is set ot on.
2 check your manual to see if the camera has a factory reset this may also be in the camera settings.
test,
if you are sure the flash is on leave the camera for a while and when you switch it on quickly hold it to your ear and you should hear a faint whining sound that is the flash charging up, if you dont hear that sound i would suspect the flash is not on if you do get the sound but the flash does not work possible it is defective.
3 suspect light sensor on camera is fefective and camera can not tell it is dark enough for flash.
Posted on Nov 13, 2009
My camera become on but the lense is not open.repairer told me that your camera s board is burn and we should buy another and now we have not any board.casio ex-p700
If the estimation of the main control board is high it is better to buy a new camera with better feaures than to invest on old technology.
So try if you get some benefit from scraping the camera for spares.
Jul 05, 2011 | Casio Exilim EX-P700 Digital Camera
Any one know of a quality place to get my ex-p700 "tuned up"? sporadically shuts off . . . and the view finder plastic pc is loose / falls off . . . just didn't' want to glue that myself . . .
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Casio Exilim EX-P700 Digital Camera
Driver for casio camera
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sep 08, 2007 | Casio Exilim EX-P700 Digital Camera
Casio ex-p700 driver
Sep 06, 2007 | Casio Exilim EX-P700 Digital Camera
My Casio P700 won't flash
Hello Betz, You are right, the flash capacitor isn't charging. The camera however doesn't have a sensor monitoring the capacitor charge, but has one on the circuits that charge the capacitor. If they aren't powered on (because of faulty connectors or damaged components) they will not be able to suply power to the inverter circuits that will charge that capacitor. The led is blinking because at some point the charging tension is sent to charging circuitry but doesn't stop blinking because charging doesn't take place or it takes place but the wires that carry the "I'm charged and ready" signal are severed or don't make a perfect electricaly contact. I don't recomand a DiY fix for this because by opening the camera you can damage the lens assembly or expose yourself to some 300-350Volts from that capacitor if it's charging. If you decide to try to diagnose yourself this problem I can suggest you to check if that capacitor is storing some tension on it, if it does, then the problem is shurely related to that "I'm charged and ready" signal wire. In either case all the connectors must be checked. Please note also that if the inverter, or charging circuitry is broken (damaged components) the service centers will change it as a whole and woun't try to repair it. This will cost about $50-$80 without labor part. Please post a reply if you nead more directions. Good luck.
Apr 02, 2007 | Casio Exilim EX-P700 Digital Camera
Why do some images recorded with flash come out looking a little dark?
Recording a subject that is outside the flash range can cause the subject to appear dark in the resulting image, because not enough of the flash reaches the subject. When this happens, you can use flash assist to correct the brightness of the recorded subject, so it appears as if the flash illumination was sufficient. Note, however, that recording certain types of subjects may not produce the results you expect, even if you use flash assist.
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Why are my flash images out of focus?
This could be due to any of the following reasons. 1) A dirty lens can cause whitish blurring of an image. 2) Light from the flash reflected back from the subject can cause blurring and a feeling that the image is out of focus. 3) In total darkness when AF measurements are impossible, the camera focuses for about 2 meters. Subjects that are closer or further will be out of focus. The Auto Focus Frame is red when AF measurements are impossible. In this case, use manual focus (MF).
Why does the date and time setting screen appear when I turn on the camera?
Turning on the camera while the date and time are not set or after the date and time settings have been cleared due to a total cut off of power (which occurs when batteries are dead and the camera is not being supplied power via AC adaptor) causes the date and time setting screen to appear on the monitor screen. When this happens, be sure to set the correct date and time before doing anything else.
Can this model record without a memory card?
This model comes with 8.9MB of flash memory built in, which means you can record without using a memory card. Even when using flash memory, however, you still need to set the correct date before recording. If you do not set the date, certain functions may not operate and proper image recording may be impossible. Also, folders created automatically by the camera will not be named correctly if you do not set the date
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
