Question about Apple Computers & Internet
I just want to ask if this kind of subject which is CISCO networking is really a hard subject? we are really afraid that we can passed this subject....can you please answer my question...
    Guru:
  • 480 Answers
Yes it quite hard subject but very beneficial and can generate a lot of income. Also enhance you knowledge and gives you a very broad understanding of internet and network.
Posted on Nov 13, 2009
Connecting Cisco 851 cable to virgin media super hub Problem
are you using the cable modem as your router? if so then simply hard code your media hub to a static ip address in the same range that the router/modem communicates on. (private address side)
Dec 27, 2013 | Computers & Internet
The router starts and finish POST then decompress image file from flash memory then shows this message: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1) Technical Support:...
I don't really know what your asking but i guess you want to know why your startup-config doesn't load. What your router is displaying is normal. You need to change the configuration register.
1.Let the router load then if asked select Yes to abandon autoinstall, then select No to skip initial setup. Press return (enter button) when asked.
2. Now type the following at the prompts. (you type the bold stuff press enter after each command)
router>enable
router#conf t
router(config)#config-register 0x2102
router(config)#exit
router#reload
........save changes blah blah blah.. type NO
continue with reload Yes
providing you have a startup-config, the router will now load it on bootup.
Hope this helps
Pokeabeaver
May 12, 2011 | Cisco (1841) Router (cisco1841)
How to export log from CISCOASA?like other cisco device logging 1.1.1.1 i want similar kind command in CISCO ASA
ASA's log is usualy stored localy on ASA itself, so easiest way to export that log is to go with telnet/ssh/console on it, do a command : show logging and copy/paste output into a new file.
but beware - this log is really short and as soon as ASA is rebooted - it's gone.
you could set asa to log to a syslog server (free on linux/freebsd or for windows use KIWI app).
that way all ASA log output is stored on pc/server running your syslog server.
Jan 03, 2011 | Cisco ASA 5510 Firewall
What is cisco cobo
Cisco cobo is ment for small businesses its a Network attached storage server running a small linux operating system. There are different sizes of hard drives and in most cases more drives can be added.
basically its the same as a USB hard drive, but its connected to a network and all computers in that network can access the files on it.
Nov 30, 2010 | Cisco COBO SMALL BUSINESS NSS3000 NAS 1TB...
How do i put in my code am doing my setup and they ask me to go to my pc and enter the code on my tv screen.
Hi
Thanks for your question.
To connect to wireless network you need to
1. Know the name of the network (provided by Internet Service Provider) and WPA pass phrase.
2. Make sure that wireless connection on your PC is enabled
3. Once your router is switched on you should be notified by your computer that wireless networks are available.
4. Click Start---> Connect to---->Wireless network
5. Click show available networks and choose your network
6. Click connect and PC should ask you for password put the password in the box and confirm.
7. By now you should be connected to the network
If you find difficulties setting this up please do not hesitate to ask more questions. I will be more then happy to help you. Good Luck
May 01, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
Hi, what's a password on the router Cisco Catalyst 2960 default?
Try using username (none) pass public/private/secret or
cisco - cisco, ADMIN - changeme, pixadmin - pixadmin, root - attack, superuser - superuser as username - password. These are the defaults credintials for the Cisco routers.
Stelios.
Feb 22, 2010 | Cisco Rf Catalyst 2960 24-PORT 10/10
Unexplained network problems.
I would be glad to help with this.
How many VLANs do you have? How many users per VLAN? Do you have a generic diagram (stripped of all company info) that you can share? Can you send me a "sh tech" from the core switch so I have a better feel for how things are configured?
Thanks!
May 27, 2009 | Cisco Catalyst 3750G-24T SMI...
Setup networking between two lan via isdn connection
This can be done using cisco routers with an isdn port on each. I'm a bit rusty on this, but could look up the details if you want. Don't be too afraid of the costs, as you can get the right boxes off ebay quite cheaply if you really want to do it. Maybe there's another way I don't know about..
Apr 27, 2008 | Computers & Internet
Switch install help
Sorry about your Admin.  With Cisco this is NOT an easy task.  Did the admin have ANY documentation on the network?  Do you have VLAN's? The IP's are set by the Admin after he figures out what is next in line for the configuration HE setup.  If its setup DHCP, that means a server will figure the IP for you, but for that to work it has to already be setup across your network.  Go into the cisco router already setup and see whats going on there.  To get in you will need passwords probably 4 if setup in a typical Cisco manner. go to this link it will help you get started: http://www.fantek.org/cisco/wpbascom.htm
be careful what you undo, you can bring down part or all the network or the internet connections.
now you know why cisco people get payed the big bucks...good luck to you
Oct 12, 2007 | Computers & Internet
Computers & Internet Logo
133 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
