Fedders furnace CUG080N2D ser #768541 how old is this furnace
Fedders gas furnace exhaust fan comes on but will not ignite
The induced draft motor you describe has a pressure switch proves the induced draft motor is running, it is about 4 inches across and silver and flat and round, it has 2 wires and a tube that atttaches to the induced draft assembly onto a barbed port, this barbed port will obstruct with carbon and needs to be cleared annually with a tiny dril bit or similar device.
Jan 24, 2014 | Fedders Heating & Cooling
Almost any hardware store carrys a good selection.
Nov 11, 2013 | Fedders Heating & Cooling
Unit is 3 years old (I just moved in) and is acting like a poltergeist... it's turning itself on and off and is beeping.
the control boards go wacky in them and then the things get a mind of their own with no control over them whatsoever. You can buy control boards for some of them, but they are often half or more the price of a new one...
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Apr 23, 2011 | Fedders A6X05F2D Air Conditioner
How old is a ruud furnace model number ugaa- 08KC, ser. number RN3D104F18794988
Hello, The model number for Ruud/Rheem equipment is located in the 12-13 digits, these appears to be a 1994. I have seen some furnaces with an age older than when the home was built (a 1995 furnace in a home built in 2000), so good job checking the serial number. This gives you the age it was manufactured.
Hope this helps James
Apr 03, 2011 | Heating & Cooling
I want to replace the old furnace in my house, I have two options: Fedders 95% Variable speed 2-stage or Tampstar 95% Multispeed Single-stage. Which is the best?.
The 2-stage unit will give you better variable efficiency under differing temperature conditions than a single-stage would. If I had to choose I would pick the Fedders unit, between the 2 you listed. (I install HVAC components for a living...)
Nov 11, 2010 | Heating & Cooling
New Furnace Coleman Model 8623A Ser#037873318
Red wire to R. There may be a R, Rc, Rh, You will have either one or 2 of these. They shaould be jumped together with a small jumper from the factory. Then white to W, green to G and yellow to Y
Mar 20, 2010 | Coleman Heating & Cooling
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
Heating & Cooling Logo
279 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
