Question about Kenmore 22422 Top Load Washer
Our Kenmore series 90 washing machine just started making a clunking sounds during the spin cycle. What should we check?
  • mathapr17 Nov 14, 2009
    It's 110.28912791
  • oldguy5 May 11, 2010
    Can you provide the exact Make, Model and Kenmore model number? Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.
    President:
  • 1,937 Answers
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.28912791
There are a couple of places to check, assuming that it does spin and drain correctly.
First, see if the tub stalls when the "clunking" sound happens. In order to do this you'll have to by-pass the Lid Switch.
It's not as difficult as it sounds.
See the following for how to tilt the console back.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=bce33cd8b32f440a0adb6e8170d95aea
With the console tilted back and the lid switch connector un-plugged, by-pass it by using a short piece of insulated wire between the two outermost pins on the connector connected to the console.
See the following Whirlpool / Kenmore Service Manual for these washers. It has a description of how to by-pass the switch.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
With the switch by-passed,start the washer and move the timer to the spin cycle. Watch the tub to see if it hesitates when the machine clunks.
If the tub hesitates, pull the agitators and the drive block. You don't have to buy a special spanner wrench. I've used a short 10" pipe wrench hooked around one of the tabs on the spanner nut and tapped the handle of the wrench with a hammer.
Also, use a short piece of wood under the drive block to protect it when you tap it up.
Check the drive block slots and the tabs on the spin tube.
If both are OK, remove the cabinet, pump, motor and transmission.
Check the cam on the basket drive and the springs / bands on the clutch.
If either of those are damaged or worn see the following Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
The Sears site also has part numbers for a clutch rebuild kit.
Posted on Nov 14, 2009
My kenmore series 80 washing machine makes a clicking sound during the spin cycle.
Might be something lodged in the drain pipe on the drum, such as a coin or similar object.
Dec 20, 2011 | Kenmore Washing Machines
Squeaking washing Machine during spin cycle
Hi
Loks that your machine is pretty old and hence the belt has hardened making a squeaking noise.
Good fix is get a new drive belt.
OR
Quick fix is you could put some oil on the drive belt..... it will work for now but not a permenant solution.
Regards
Berry
Feb 01, 2010 | Kenmore Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Series 90 washer loud clicking during Slow wash cycles, Fast OK.
Turned out to be a loose electrical connector near the motor.  Plug was re-connected and secured with a zip tie to prevent another disconnect.
Apr 03, 2009 | Kenmore Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore series 80 washer that is making a loud clunking
check the motor coupler between the gearcase and motor for wear. If it is cracked or broken it will need to be replaced
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Squeaking/grinding/rattle noise during wash and spin
That sounds like a clutch problem - probably just worn and need replacement. Will definitely need to pull to find exact fault.
Regards
Nov 16, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
253 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
