Question about Samsung SyncMaster 205BW LCD Monitor
"Check signal cable" appears on the screen. I have disconnected
I have disconnected and reconnected all cable lines. I am getting a feed because I M using the same feed off the wireless modem for this communication. Ideas?
    President:
  • 1,187 Answers
The cable that connects the MONITOR to the COMPUTER is loose or disconnected. Check the monitor cable at both ends. (not the wireless switch, router or modem).
Posted on Nov 13, 2009
Why do yellow lines appear on the screen when I turn it on?
1. Screen connector cable has been displaced or disconnected from the base connector slot in the main board...
to solve this, you need to open the back cover of the laptop and reconnect the screen cable correctly
2. Your screen have burned pixels.
to solve this, you need to replace the LCD screen.
Apr 20, 2016 | Computers & Internet
Small rectangle in the middle of the screen with the letter i in the left corner, the buttons are lockeder la hello 17
If the picture disappears from the screen and the
1 (power) indicator is green
Turn off the 1 (power) switch and disconnect the
video signal cables from the monitor.
Turn the monitor on by pressing the 1 (power)
switch.
If all four color bars appear (white, red, green, blue), the monitor
is working properly. Reconnect the video signal cables and check
the condition of your computer(s).
If the color bars do not appear, there is a potential monitor failure.
Inform your authorized Sony dealer of the monitor's condition.
Be sure to note the model name and serial number of your
monitor. Also note the make and model of your computer and
graphics board.
Mar 18, 2014 | Sony SDM-HS75 17" LCD Monitor
Lines on the screen LCD Bravia
There is a circuit board with one or two wide flat ribbon cables coming out of the display screen into the edge of the board. Try disconnecting and reconnecting these cables a few times to re establish a good connection. If this doesn't solve the problem , then get all the numbers you can find on the board and replace it with a new one.
Jan 05, 2014 | Sony BRAVIA Televison & Video
When on "computer" mode I
disconnect the cable at the projector end and plug into a monitor to check that the video signal is enabled on the cable. If it is then reconnect to the projector and select a lower resolution on the pc screen setting. See if anything appears on the projector
Aug 24, 2011 | NEC MultiSync VT590 LCD Projector
Screen will not stay on, getting message no input signal
The message input signal means no signal is being feed to the monitor.
Check the cable use to connect the monitor to the video card.. fix and secure the connection.
If the computer is reading and you know its working, check the video card.
Turn off the CPU disconnect the video card from the motherboard and reconnect.
Try to open your CPU and see if it reacts with your monitor. If nothing happens replace your video card
May 18, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My samsung 940N acts like a florescent tube, tries to start and doesn't
Use the self test feature.. follow the steps..
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
Feb 13, 2010 | Samsung SyncMaster 940N 19 inch LCD...
White horizontal lines appear in the screen
you may just need to reseat the cables. basically all you have to do is take the keyboard bezel off of the laptop and disconnect and reconnect the cables on the lcd. you usually do not need to unscrew anything but a pick would help. Just simply pry it off using a pick or small flatheadd80ef8a.jpg
Dec 08, 2009 | Sony VAIO VGN-CR220E/W Notebook
Connected set box to component 1 input and gets no sound. Disconnected and reconnected and still no sound. Speakers are on. Plugged of DVD player and had sound.
Are you using all five cables? RED, BLUE, and GREEN for the component video, and a set of RED and WHITE for right and left audio. Also try using the audio line of the set top box feeding a set of PC powered spekers just to verify that the box is putting out audio signals.
Dec 08, 2009 | Vizio L37 Television
Proscan PS50700
Appreciate the direct "Ask Me".
Technically, when a TV signal is said to be snowy, it indicates that the incoming RF signal is weak; on the other hand, when a TV signal has static, this refers to electrical noise that goes with the TV signal.
Having said that, then to your concern:
  • for snowy signal, it is the cable providers problem. They have to change where your incoming cable is tapped from, check/replace the feedin cable itself or worst case scenario, replace the line amp/distribution amplifier feeding your cable input;
  • for static noise, what is required is to check possible sources which could include (but not be limited to) electronic ballasts of florescent lamps, electric fans, hair dryers, shavers, wireless phones, computers and others.
Additionally, you may want to check if you have any RF producing devices attached to the TV such as VCRs, DVDs, game consoles. You can try unplugging them when not in use.
Worst case scenario is the tuner block of the TV is getting weak (unlikely but possibly). You can try rewiring the cable to feed first into a VCR, connect the VCR to any of the free Video IN, and select channels through the VCR. If significant improvement, then you have just confirmed an internal fault with the TV tuner, if problem persists, then the static/noise/low RF is caused by something else.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 31, 2008 | Samsung TXE2745 TV
Samsung SyncMaster 205BW LCD Monitor Logo
334 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
