Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Our units compressor is making like a on off noise and our freezer is not staying cold enoough allowing food to thaw
  • 2 more comments
  • poshmom Nov 13, 2009
    how can I tell which one it is the relay or the compressor
    MN fisherman
    How can I tell the difference between a problem with the relay and a problem with the compresser
    thanks Chuck
    Thank you chuck for your input my husband says that makes sense.
  • 4,066 Answers
It sound like the compressor is kicking off. This can be caused by the starter/overload going bad. How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Posted on Nov 13, 2009
  • 11,896 Answers
Either the relay is bad or compressor pump is bad.
All my food thawed in my freezer. Is it just defrosting or is it broken?
Most newer freezers have self defrosting. But it will not thaw out the food at all. For it to thaw completely in 1 day, the compressor did not come on at all. I would first check the fuse or circuit breaker in your home. Many different issues could cause the same result of the freezer not getting cold at all. Defective thermostat, defective compressor, refrigerant leak or loose wiring at connection points. It could possibly be stuck in the defrost mode too.
Oct 30, 2015 | Refrigerators
Help!! A couple of days ago, freezer food thawed and. regerator food warm. There are some cold spots in freezer and frig, but not uniformly cold. Compressor seems to be working. There is a fan blowing...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 21, 2011 | Frigidaire Refrigerators
Refridgerator and freezer not cold enough. Food is thawing and not staying cold enough. Fan is working. not making any weird sounds. No frost build up in back. Vacuumed and wiped down condensor.
heatman101
Mar 20, 2011 | GE GSL22JFPBS Side by Side Refrigerator
I opened the freezer this morning and all the food was thawed. The air blowing in the freezer was not cold at all. I opened my fridge and noticed it was feeling much less cold?
your ptc overload relay on the compressor needs replacing,unplug it off the compressor in the lower rear area of the unit and obtain an exact replacemect and it will again operate and cool
Mar 04, 2011 | Refrigerators
I bought a model FRT18B5JB2 in August 'o9 to put out in the garage for extra cooling and freezing room This winter the freezer is not keeping items frozen. They are no thawed completely, but they are not...
Refrigerators do not work correctly in the winter in unconditioned space.
It is too cold for the unit to run normally.The compressor oil gets sluggish and strains the compressor when it does run.
The thermostat never warms enough for the unit to come on and run.
Therefore the temperatures in fresh food and freezer stay at the top end of the set point. This would cause about 42-43 in fresh food and around 18-25 in the freezer.
In the spring time it should start running correctly again.
Feb 14, 2010 | Frigidaire Refrigerators
Maytag Performa PTB2153GR making a clicking noise and food is thawing in freezer, fridge not staying cold
check no ice around pump unit. then try manual defrost both.no hot water. clean filters/drain holes.dry as best you can then switch on.
use thermometer to check temp -20c in freezer
Feb 07, 2010 | Freezers
Refrigerator/freezer won't stay cold.
With the defrost timer being replaced already it sounds as if the repairman is not looking at the real problem. Unit works for 2 days then things start thawing. Hint Hint... it is not defrosting. There is a heating element inside the freezer section attached underneath the internal tubing that melts the ice every 6 to 8 hours via the defrost timer depending on the defrost timer installed. To prove that it is not defrosting..... just unplug the unit and place a stand fan blowing into the freezer for about 90 minutes. I would bet that once you plug it back in it wil work for 2 days and the problem once again repeats. With 2 calls on the same unit and you still have the same problem I would be calling the service people back and demand they fully troubleshoot the defrosting element and thermostat. Personally this is an unstatisfactory performance of an in home service by a repairman. With the exception of a new part if required, they should wave any labor and service call fees.
Jan 02, 2010 | Whirlpool Refrigerators
Fridge working off/on
If the noise was coming from the compressor when it was cutting off or starting, it was the internal mounts of the compressor and the compressor will have to be replaced. If the noise was a fan, it may have stopped. One is in the freezer behind the rear cover and one is underneath where the compressor is behind the cardboard cover.
Dec 31, 2009 | Whirlpool ED2FHSS Side by Side...
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
32 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
