Question about Dell OptiPlex GX280 PC Desktop
Need instructions on how to install Memory module for OptiPlex GX280
    Sergeant:
  • 267 Answers
Ok lay computer down plat. there are two grey buttons on the side.
compress both at same time.
lift and unit should open
you will see one or two green sticks about 3inches in size sitting in a slot call a address bus. on each end on the slot there are one lever to release the ram from its slot. . make sure you have unpluged unit from the wall socket. DO NOT stand on carpet this will release ESD. elictro magnetic discharge. remember which way the ram stick is facing press down on both end levers and remove the stick from its seating.
put new ram in the same way you took the old 1 out . levers will snap back up into place when you have it seated correctly.
close unit and boot unit. if a blur screen appears shut down and reopen unit repeat procedures by switching the rams around. if problem persist your ram is not compatible and you may have to get a two 512s or so on. i hope this was helpful.
Posted on Nov 13, 2009
Intel gma 900 integrated ram
assuming you need a RAM upgrade... the GX280 uses DDR2 PC5300 memory, and can support up to 4 1GB sticks of memory.
Oct 07, 2013 | Dell OptiPlex GX280 PC Desktop
Keyboard & Mouse not inputting..Dell OptiPlex GX280.. OS, XP. Microsoft Wireless Desktop 3000 (keyboard/mouse) new.. Dell boots up and desktop appears, the cursor (arrow head) remains in middle of...
Check that batteries are charged and installed properly.--make sure driver disc is installed if applicable- check instructions as some wireless suites need you to push a small connect button to initialise them . Also try shifting the usb conector into another USB port if it is notm getting reconised.
I hope this helps
Andrew.A
Apr 09, 2011 | Dell OptiPlex GX280 PC Desktop
How do i open my dell computer to install new memory module
Most PC had 3-4 screws on the back.Unscrew tehm and slide the side of the case back until if completely out. There you will find the Mmodules.
Oct 15, 2010 | Dell OptiPlex GX280 PC Desktop
Hd keeps rebooting. I swapped drives, battery, memory and still the same so it must be something with the motherboard. Any suggestion. It's a Dell Optiplex GX280 desktop
It could also be the processor, either its overheating or it has simply packed up first check that the heatsink above it has been correctly installed and is resting directly on top of the processor and that the fan on the heatsink is functioning. If that doesnt work then replace the processor completely.
Jul 15, 2010 | Dell Optiplex GX280 (99301) Motherboard
Optiplex gx280 processor upgrade
eykraus,
I have some experience in upgrading your Dell.
If this gx280 was my computer and want to upgrade I'll only go to 3.0 but you need to upgrade you bios to support the new upgrade. You could also upgrade the memory as well. Put the power supply you have in so you can conserve.
Sep 05, 2009 | Dell Optiplex GX280 (99301) Motherboard
No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Aug 16, 2009 | Dell OptiPlex GX280 PC Desktop
Dell GX150 beeps 5 times on startup.
This normally means there is a memory error. Have you recently added memory to the sytem? You can try to remove and reseat all memory modules in the system to see if that clears the problem.
Jul 10, 2009 | Dell Optiplex GX280 (99301) Motherboard
I installed 4gb of memory 4x1GB 240 pin and when booting up the computer recieved the decomplilation or disassembly prohibited.  What do I do?
HI there,
If you have installed the memory module correctly and are the right ones, than go into your bois and in there should be overwrite o clear this message.
Its only an alert message when you pc has been opened.
Regards,
Philip
Dec 06, 2008 | Dell Optiplex GX280 (99301) Motherboard
Dell PE 1600SC invalid memory configuration detected
You may need to install memory in matching pairs. If the new memory is a single 1Gb module and you didn't already have a similar one they may not work together. Try removing the original module(s) and see if it makes a difference.
Oct 28, 2008 | Dell OptiPlex GX280 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
