Question about Frigidaire GLGQ2152ES Gas Dryer
Code E68, and a lot of beeping. - Frigidaire GLGQ2152ES Gas Dryer
  • 11,896 Answers
The control board is faulty.
You can get parts and manual at repairclinic.com or partselect.com
Posted on Nov 13, 2009
I have a frigidaire affinity that is beeping with code E68 HELP???
Good Morning Friend,
I understand that your Frigidaire Affinity dryers is beeping and displaying an E68 code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Dryers
Was receiving E68 code on Frigidaire GLEQ2152ES1, replaced circuit board and am still receiving the e68 error code. What else will cause this error?
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
Aug 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its then you press buttons and it beeps continuosly...
that's a lot of kids... according to the Frigidaire wiring diagram and codes list E68 means a key is stuck or bad board. You can enter function test mode and check which button is at fault. Hope this helps Tim
p.s. here is a thread:
http://forum.appliancepartspros.com/dryer-repair/143380-frigidare-affinity-dryer-e68-error-code.html
Apr 06, 2011 | Dryers
E68 error message
The code is for a stuck button on control panel. You will need to replace the control panel
May 16, 2010 | Frigidaire GLEQ2152ES Electric Dryer
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
The e68 keeps popping up on my time window. Have
You can contact this guy...seems others have had the same problem with some frequency..send him your contact information...model and serial number...he's THE guy to talk to with Frigidaire. Chris Polk
Escalation Specialist
electrolux Major Appliances
chris.polk@electrolux.com Another tech had this information to share: 6 beeps / E68 - Push button does not function
Cause:
Solution:
Disengage button.
Try doing that first if the error code still shows up, then you'll likely need a new control board assembly.
Here's the one for your model:
Manufacturer part#134523200 is RepairClinic item#1154933
May 02, 2009 | Frigidaire Dryers
Dryer keeps stopping error code e68
E68 error refers to "Current leakage to ground on heater or fuse opened".Problem with the fuse.Try getting it replaced.This can be done by any local repairman.Need not be a technician from Frigidaire,as they charge a lot for servicing. Good luck with the machine.Please do post results and comments.
Apr 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Code E36 and Code E68
hello e36 means control board problem E68 means current leakage to ground on heater or fuse opened
shaun
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Our dryer is beeping and is displaying an error code of E68. I hit Cancel to try to reset it, and it goes back to numbers (20 minutes or whatever), then after a couple seconds goes back to E68. I hit...
I found via a Google search that E68 means one of the keys is jammed. Looking at it, it was pretty obvious which one, so I pushed it in and re-centered it in its casing. That did the trick.
Jul 05, 2008 | Frigidaire Dryers
Frigidaire GLGQ2152ES Gas Dryer Logo
191 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
