Question about Transcend (TS40GSJ25) 40 GB Hard Drive
I have problem with running my 40 GB
Hello
  • imendarb Jan 08, 2008
    all other four icons on my TS40GSJ25) 40 GB Hard Drive interface utility are working well but when I click on outlook express icon on TS40GSJ25) 40 GB Hard Drive desktop device, the following message is appeared with this title
    ( identity switch cancelled )
    The current identity could not be changed because one of the applications was unable to switch.
    close any open dialog boxes in other applications before trying again
    For your information, I could open easily the outlook express that is installed on my PC but the problem is while we want to open the outlook express that is on store jet
    I also checked that on my laptop and the same message appeared
    Please let me know what to do.
    Regards,
    Iman
Hola
Espero entiendan Español, tengo problemas con mi TS40GSJ25, por error al instalar Windows eliminé la partición del disco externo, que se encontraba conectado al momento de realizar el proceso. Me parece que eliminé la partición que trae el storjet. El problema que tengo en este momento es que al tratar de ponerlo a correr, me indica que la unidad no tiene formato y me pregunta si deseo darsela y cuando acepto esto no sucede y no puedo almacenar información, ni abrir los archivos que provablemente se encuentran borrados. Espero me puedan ayudar.
Muchas Gracias y espero tengan gente que entienda Español y me puedan ayudar a mi y a otros que hablan mi idioma.
Posted on Jun 09, 2008
    Problem Solver:
  • 9 Answers
Hi, problems with "running" your 40 GB Hard Drive?
Is it hooked up properly? Do you know how to hook it up?
Is the power cable hooked up to it? The IDE or other "data" cable properly connected to it?
Check all items with the connection with your hard drive.
If this isn't your problem, please repost.
Best of Luck.
~Ominious Depression
Posted on Jan 08, 2008
6ya staff
SOURCE:
I have a trancend storejet 2.5, and now it doesnt show up on my computer. it lights up and the disk spins but it doesnt show up on the computer anywhere, not even in disk management. it doesnt work with...
Hello Anirudh,
To run the hard drive in Linux
Connect to the Internet. You will need access to the Internet to download the install files.
Open your Terminal in Ubuntu. This is the screen with the prompt where you can type commands.
Type "sudo apt-get install Gparted." Type in your root password and answer "Yes" to any prompts.
Type "sudo GParted." This will open GParted.Click the GParted menu and select "Devices." Select your external hard drive from the list. It is important that you choose your external hard drive and not the drive that has your system installed on it. One way to ensure this is to check the capacity on this drive; for example, if your internal disk is 80 GB and your external disk is 40 GB, choose the disk that is 40 GB.Click the "Devices" menu and click "Create Partition Table." Click "Advanced." From the New Partition Table menu, choose an option, depending on your system. For example, if you are dual booting Windows and Ubuntu, you may want to choose MS-DOS. If you are only running Ubuntu, choose GPT.Create a partition. Select a section of unused space and click "New."Set up your partition. For partition size, set the size of your partition--for most purposes, you can make the partition the entire capacity of the disk. Next, choose a partition type; primary is suitable for most purposes. Next, choose a file system. For sharing across a Windows system, use Fat32. For sharing with an Apple system, use HFS or HFS+. For use with an Ubuntu system only, use EXT2, EXT3 or EXT4.Click "Apply." The operations will run and your hard disk will be ready to use.
Apr 14, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Computer won't wake up after being left on at night
Some PC go into hibernation after running for a long time. If it is "sleep" just press and release your power button to return to normal function.
Good Luck
C2S
Jun 26, 2010 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
I have a problem with the HD. It is not working.
Well the hard drive on the laptop now is 40 GB. It is an ATA hard drive so you need to buy an ATA hard drive of xx gb. You choose the capacity, but considering the characteristics of your laptop it should be fine a 80 GB or 120 GB. (i mean the RAM is only 256MB and the data transfer will be slow).
It you need further assistance, leave a comment. Cheers
Jun 07, 2010 | Fujitsu AMILO Pro V1000 Notebook
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
Hard disk problem
your hard disk is developing bad sector (it will be dead) so better to backup your data
May 17, 2008 | Samsung Spinpoint MP0402H 40 GB Hard Drive
Hard drive turning on and off repeatedly
just restore ur system to previous date so that everything may go fine ...
Dec 18, 2007 | Western Digital Protege WD400EB 40 GB Hard...
Disk not being Recognised: Windows XP asking for driver
s cuase u r using ur hard disk with different mother board so u need to format it or u need to get teh mother board cd an dchange the boot sequence as cd-rom and run it
Oct 31, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Hard disk not detected
The problem is that u have done partitions for 160 GB harddisk, so do all the partitions of 40 GB or less than that.
Sep 24, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Transcend (TS40GSJ25) 40 GB Hard Drive Logo
193 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
John Porter
Alun Cox
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
