Question about PfaFF Creative 7570
Need PC Designer for for 750 windows xp/where?
Have an old version of PC-Designer for Pfaff Creative 7570 version 2.1. Replaced old computer with newer one using Windows XP. How do I get upgrades so I can use PCD on present computer. Suggestions?
    New Friend:
  • 5 Answers
PC Designer is no longer supported. You can still install version 2.1 on Windows XP. Once installed right click on the icon that was created on your desktop and check the box next to compatibility. This will "dumb" it down to an earlier version of Windows. PCD will not work on Windows 7.
Posted on Oct 11, 2014
    President:
  • 1,015 Answers
If you purchased the software after April 1st,2006 then you will be entitled to a free upgrade. If not you might have to purchase the software. Here is a link to the PFAFF software download page. http://www.pfaff.com/global/11283.html
Posted on Nov 13, 2009
I have a 7570 phaff sewing machine and a new windows 7 PC What will I use to transfer my patterns to the machine
Hi franlove
I had the same problem when I upgraded to a laptop with Windows XP. I needed to buy a Keyspan, which connects via the USB on the computer to the machine via the pc connector that comes with the Pfaff 7570. However I had many problems after that, and found that the Keyspan transfer rate had to be slowed down to 2400. Of course 3D is the most recent Pfaff software that the Pfaff 7570 will work with. Anything older is OK.
Hope this helps. I will look up the steps that I went through to slow the transfer speed from the Keyspan if you need me too.
Good Luck
margielydia
Dec 29, 2010 | PfaFF Creative 7570
Connect PfaFF Creative 7570 to a PC
The software you need to connect the Pfaff 7570 to the PC and to create your designs is called PC-Designer version 2.2 from Pfaff. You may be able to find a used copy. The software should come with a dongle (special cable) for connecting the machine to the PC. Make sure you have this piece because it will not work with an ordinary cable. Depending on what type of port you have on the PC to connect to, you may also need an adapter since the dongle has an old style connector on the end going to the PC. If you are going to create your own designs, you will also need a storage card which inserts into the machine that you send the designs to. Pfaff makes one, called the creative card. I have also used a generic card meant for the pfaff; the generic card is less expensive and has a greater capacity. You can find many designs online either free or for sale to send from PC to Pfaff as well.
Nov 27, 2009 | PfaFF Creative 7570
Hi I'm Kandy When I try and load a card stitch I keep getting the following error message: PCDWIN22 Caused a General Protection Fault in Module PCD_WIN.EXE at 0005:38F6. The software then shuts down. I...
I replaced my USB/Serial RS232 port adapter with a genuine RS232 serial port on the PC. THis solved the problem. Further reasearch on the net indicated that USB to RS232 - serial port converters do often have problems. I previously had not had a problem running on Windows XP and this is what alerted me to the possibility of the USB/RS232 port adapter as a possible reason for the "new" problem.
Oct 24, 2009 | PfaFF Creative 7570
I have (pfaff 7570) pc designer software on floppy disk, no floppy drive, where can I get a download for the software
You will need to purchase an external floppy drive. There is no download available for software.
Sep 20, 2009 | PfaFF Creative 7570
7570 connection
I have Windows Vista; I also had a similar problem; found out that I could only use the usb port on my computer exclusively for sewing as the driver software seems to conflict;
Also, having said that, go to Pfaff.com & download the free driver upgrade and see if that will get you started good luck deb
Jun 24, 2009 | PfaFF Creative 7570
No communication with the machine.
contact the manufacturer your new system may not be compatible if it is windows 10 .probably a driver problem
Apr 30, 2017 | PfaFF Creative 7570
Sewing Machines Logo
1,080 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
