Question about Motorola Walkie Talkies 2-Way Radio
I am using Motorola T5950 and have it set to Channel 7 with ICE to 4. Hunting buddies have Cobra Microtalks set to Channel 7 and ICE 04. I can hear them but they cannot hear me. Can I rectify this? Thanks
  • onlylabs Nov 13, 2009
    Just to clarify the T5950 cannot be set to 04 on the ICE but the Cobras can.
    I have the QT settings turned off also. Thanks again.
  • Motorola Master
  • 1,654 Answers
Check to see if your Qt filter is turned off. This is an extra filter the T5950 has to block out other users. It is possible you have yours turned on and it is blocking the cobras.
If it isn't the Qt filter, set all the radios to have their ICE in the off position (usually zero). The radios should then be able to communicate. It could be the ICE is slightly different between the brands.
Posted on Nov 13, 2009
How can i channel my T5950 with my GP200-
You have to change frequency in gp200 to make this you need help your local motorola service
Apr 02, 2010 | Motorola Talkabout T5950 (7 Channels)...
T5950 talk about
Check your frequency, code and Qt filter settings. All must be identical. For basic operation set the code and Qt filter to off (zero). Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T59xx_User_Manual_E.pdf
Best regards.
Feb 06, 2010 | Motorola Talkabout T5950 (7 Channels)...
T5950 Talk abouts
They are probably not programmed to match one another. There are 3 key settings on these radios: Frequency, Interference Eliminator and Qt Filter. If you walk through the programming instructions for each of these and set them identically, they should communicate.
Feb 03, 2009 | Motorola Talkabout T5950 (7 Channels)...
To stop the beep when keyed
Hold in the minus (-) button while turning on the radio will shut off beeps.
http://www.usersmanualguide.com/motorola/2-way_radio/t5950
Nov 15, 2008 | Motorola Talkabout T5950 (7 Channels)...
T5950 2-way
Initially, pls check that the displays of both radios are identical. This is important to establish that the channel/frequency, Interference eliminator settings and all others are the same that both are paired. In some instances, the radio settings may not be changed if it is locked. Top unlock, press on the MENU button for about 3 seconds. For all other settings, pls refer to the user's manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Motorola Talkabout T5950 (7 Channels)...
Motorola t5950 two way raido
i do not have any experience with that model, however, i tried a cheap set a short while back, i noticed that if i tried to talk to the other portable while holding it, it would not work. i set the portable down and walked away from it, and it started to work.
maybe?
Feb 24, 2008 | Motorola Talkabout T5950 (7 Channels)...
Pair of radios won't talk to each other
Have you checked the QT filter? The T5950 have an addtional interference filter called the QT filter. It filters out other radios and allows Motorola radios to speak only to other Motorola radios with the filter. Check the QT setting on both radios by pushing the menu button 6 times, the QT setting will show. If it shows a straight line on the display the filter is not on. Now push the + button (beside the menu button), to turn the QT filter on (a Y will show on the screen when on) or the - button to turn it off (the line will show when filter is off). The radios have to match all channels and all filters to talk to each other.
Dec 09, 2007 | Motorola Talkabout T5950 (7 Channels)...
Motorola Walkie Talkies 2-Way Radio Logo
229 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
