Question about LG enV VX9900 Cellular Phone
Describe how to sync phone with blue tooth
Describe how to sync LG cell phone with blue tooth
The instruction manual to sync my lg hbm-210 bluetooth headset to my phone
Usually this can be done my turning the blue tooth on and going into your cell phone and finding where it allows you to connect to a bluetooh device once there it will say sync with device, click yes or what ever term it uses, it may then ask for a code to sync the device it's usually a code of 0000 or 1234. Hope that will help you, it's the standard way most bluetooths are synced to cell phones.
Dec 02, 2010 | Cell Phones
How do I pair bluetooth from one phone to a new phone? Removing bluethooth from my old phone to another phone.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 12, 2010 | LG Dare VX9700 Cell Phone
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
HOW TOCONNECT BLUETOOTH
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
HOW DO I CONNECT MY BLUETOOTH TO MY LG RUMOR PHNE
first thing make sure your blue tooth is fully charge and on. Then go into menu go to setting find blue tooth setting go in there make sure your phone is set on enable blue tooth then turn on searching then it should pull all the blue tooth signals that are around the phone then just select the bluetooth device
Nov 19, 2009 | LG RUMOR Cellular Phone
How to download music to lg phone from windows media
get a data cable, some usb blue toothe sets have the right cable so check the old phones/headsets before buying one. plug it in and the sync digital media files to this device, or import video and photos. This is in vista.
Nov 17, 2009 | LG Xenon GR500 Cell Phone
LG VU does not recognize my blue tooth while trying to pair two
Help my pair my bluetooth with my LG shine phone. I have a jawbone bluetooth.
Mar 23, 2009 | LG Shine KE970 Cellular Phone
Does the lg vx4650 have blue tooth capability for hands free
Looking at the spec sheet for it www.lgmobilephones.com it does not have bluetooth, but does have voice activation.
Jan 24, 2009 | LG VX4650 Cellular Phone
Pairing a motorola n136 with a lg vx5500
your phone probably is not capable of syncing into that kind of blue tooth, if not go see your cellphone dealers store they will help you.
Jan 09, 2009 | Motorola Mobility HS850 Consumer Headset
Conecting blue tooth
You did describe the full question.
If you have facing some problem while connecting via blue tooth check you these sittings
you phone have name in blue tooth
your phone should be visible on
And you should one it while connecting to any device then you can search for any blue tooth device.
Let me know if you have any other question regarding this topic.
Nov 18, 2008 | Cell Phones
LG enV VX9900 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
