Question about HP Photosmart C4180 All-In-One InkJet Printer
When I try to scan from printer to computer I get 'scan error'. See documentation. I am trying to scan to a mac - does that matter?
  • 100 Answers
You need to use the grey cd to install the software onto your Mac if you have not already done so. If you don't have the Mac CD you can download the installation software and all drivers from HP here (select your operating system first).
If you have installed it aready, try uninstalling and then reinstalling using the HP website to obtain the updated drivers etc. rather than your CD.
Once you have uninstalled the software, disconnect your printer and then restart your computer. Do not re-connect your printer until you have reinstalled the software.
To verify that the software has installed properly, look for the HP Solution Centre on your desktop, double click on the icon and check that both "scan picture" and |"scan document" are showing.
Hope that helps!
HP Support manual for C4180
Posted on Nov 13, 2009
HP Photosmart C5280 No computer connection
mail or call to the technicale support team of hp for that problem and get the folloups from them every day, i cant say much more becouse its realated to mac and for mac there is too less data available on hp sites.
Jun 13, 2012 | HP Photosmart C5280 Printer
Kodak ESP5 AiO Unable to scan to PC. Error code on opening Scanner 2106 Please advise,THANK YOU!
Please clarify a few things for me so I can help you solve this issue.
Are you trying to scan from the printer to the computer? (pushing the scan command on the printers keypad to send the signal to the computer)
OR
Are you trying to scan from the computer to the printer? (Using the scan options in your software by choosing "start" and then "programs" and opening your printers software to choose the scan option)
If your scanning from printer to computer (using the printers scan option on the keypad) and your getting an error code, chances are the problem is you have not set up your defaults in the printers menu yet. To scan from printer to computer, the printer needs to know which program you want your document to scan to in your computer. If its a text document, some people choose "Microsoft Word" and the scan fuction sends your item to that program and opens it for viewing on your computer screen.
There are different programs to use for each type of fax that need to be set up in advance in your printer to be able to scan from printer to computer. Send pictures to a photo editing software and choose the size and resolution you want as "default". Do the same for setting up text documents before you try and use this feature to eliminate the error code.
To configure your options to scan from printer to pc, push the "menu" button on your printer and use the up and down arrows on the printers keypad to move through the choices. Find the command similar to "scan options" and follow the prompts to set the defaults on handling text documents and pictures and then save your choices by pushing the "ok" button on the printers keypad.
Try scanning again with your computer turned on and open to the desktop. Push the scan button on the printer and see if it sends the image or document to your computer screen. It should warm up, then scan and show a preview on your screen for you to accept or reject. If this does not happen, please asnwer my questions as listed above and clarify what you see so I can help solve this issue right now.
Sep 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Hp 3050 scanning error message
Good day!Try to check the feeder if it has paper on it..then try on and off the printer until it holds normal status..
mastergani
Mar 29, 2010 | HP LaserJet 3050 All-In-One Printer
Scan to OCR error message
remove all associated driver and scanner software reinstall all the software with the scanner and printer disconnected then rebootit all connected. Try again
Jul 24, 2009 | Brother MFC-9840CDW Laser Printer
MP800R: Error code:201 - Printer can print but not Scan!MP800R: I can use the printer for printing al right, but when I try to scann I get a message that I should close the printer, and read the manual...
Error code:201 occurs due to USB conflict or software not running properly....
Solution#1: Take out the scanner from USB port... shut down the computer.... then restart the computer and plugin your USB plug in anyother USB port(not the ealier one).. Then check if that works.
Solution#2: Click on Start > Click on Run > Type Services.msc press ok.... on the services window check for "Still Image Service" right click on it and select properties .. then click on stop then start(if it is already stoped then click on start).... also make sure the Startup Type: Automatic....
Jul 17, 2009 | Canon Office Equipment & Supplies
Brother MF-8440 scanner driver and document manager for Mac OS X
Open preview and go to file and then scroll down to "import from scanner" MFC should show up as a choice and then when the window appears, go ahead and pick your preferences and scan
Mar 01, 2009 | Brother MFC 8440 All-In-One Laser Printer
Hp officejet 6110xi all in one
I did a search of your product's help pages on HP.com but didn't come up with an exact match for your error message relevant to an Apple Mac OS X. Before offering suggestions, let me make sure I understand the problem.
You have a Word document open on your Mac and you want to insert an image into the document that's on the scanner.
I'm actually not clear as to whether you successfully scanned an image in the first place. If you did scan the image, where did you store it to? Have you tried scanning the image and saving it to your computer? If you can do this successfully, try inserting the image into your Word document from the location on your computer.
If you tried to scan an image and got the error message, then there is a communication problem between your Mac and the printer. Since you can print, the cable connection must be good. If the error message is suggesting that you reinstall the drivers, you can find the instructions for how to do this at the following web page at HP.com:
Installing and Uninstalling Printer Software on your Mac
You may or may not have your original software disc that came with the printer. If you don't or if you need an updated print driver, you can download that software from the following web page, assuming you are running Mac OS X:
Mac OS X Printer Software and Driver Downloads
Occasionally, you can solve errors by installing print drivers that are more recent than those you originally installed when you first got your printer. That's the benefit of downloading the latest drivers from HP.
On the off change you are using Mac OS 9, here's the relevant software download page (the version of the Mac operating system matters):
Mac OS 9 Printer Software and Driver Downloads
If all you want to do is to insert an image into a Word document, you shouldn't need Adobe Photoshop or any other expensive software application. You aren't trying to do any fancy editing of the graphic, just insert a pre-existing image into a document.
I hope some of the above suggestions help. Post back your results and good luck.
Oct 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OFFICEJET 5610V No scan options
If you get the error while trying to scan with your HP 5610v All-In-One, the easy way to scan from your printer is to click on start, go to Paint and then File, the option "From Scanner or Camera" will come up.. click there and poof - you can scan anything you want and save it where you want... Problem solved!! good luck!!!
May 24, 2008 | HP Officejet 5610 All-In-One InkJet...
Won't scan document to my mac os x
download the new drivers and firmware from the HP site. that is updated and should work just fine
Apr 30, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Photosmart C4180 All-In-One InkJet Printer Logo
239 people viewed this question
Seeker5211
Seeker5211
