Question about Belkin (F5D5231-4) Router
Cant access settings page when entering ip address 192.168.2.1 it says session timed out
  • 591 Answers
Posted on Nov 13, 2009
I need tata docomo gprs setting (95 rs grps plan)
it is here
Create a WAP profile with following Settings: - Connection Name : DOCOMO (You may choose any name you like)
- Data Bearer : GPRS - Access Point Name : TATA.DOCOMO.INTERNET - Username
- Password
- Homepage
- Connection Security : Off - Session Mode : Permanent
In case of the WAP 2.0 compliant phones, the following extra settings need to be done:
- Under Options : Advanced Settings - Phone IP Address : Automatic - DNS Address : Automatic - Primary name server : 0.0.0.0 - Second name server : 0.0.0.0 - Proxy server address : None - Proxy port number : 0
If you do not have a Nokia and Sony Ericsson phone, you'll need to set your phone manually with these details. Setting Name DOCOMO (You may choose any name you like) Home page
Session mode Permanent Connection Security Off Data Bearer GPRS GPRS Access point TATA.DOCOMO.INTERNET IP address <blank> Authentication type Normal Logintype <blank> User name <blank> Password <blank>
Jan 08, 2011 | LG GT540 Cell Phone
Tip
Having trouble accessing router's setup page?
Note: If you cannot access the router's page, check the computer if it's getting a valid IP address from the router. Click Start then type CMD on the Search box then press Enter. A black window called Command Prompt will appear, just type IPCONFIG then press Enter. It will display the IP address.
- Scenario 1. If the IP address starts with 169.x.x.x --- not getting IP from router
  • Scenario 2. If the IP address starts with 192.168.1.x --- getting IP from router
  • For scenario 2, since the computer is getting IP from the router, try to PING the router to test connectivity. Open the Command Prompt again, type PING 192.168.1.1 then press Enter. If you see the word reply 4 times then it means the computer is communicating with the router.
  • Clear the cache, cookies and history of your Internet Browser then try to access the router page again.
on Dec 11, 2011 | NetGear Computers & Internet
The router was reset. So, our AP does not work with it anymore. I reset the AP to restore it to its factory default settings and tried to follow the steps I made before in configuring the AP. but i can't...
Before you configure this device, note that when the AP is configured through an Ethernet connection, (via RJ45 Network Cable) make sure the manager PC must be set on same the IP network. For example, when the default network address of the default IP address of the AP is 192.168.1.1, then the manager PC should be set at 192.168.1.x (where x is a number between 2 and 254), and the default subnet mask is 255.255.255.0.
Open Internet Explorer 5.0 or above Web browser.
Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the address location. Please refer here to the Latest User Manual for Encore ENRWI-G Page 9 onwards describes the login details.
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Computers & Internet
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
I have a SGH-A767 SAMSUNG mobile no internet connection
The best way is to call your carrier and get them sent to your phone automatically. To enter them manually:
T-Mobile Browser/Java Settings:
Connection name: T-Zones
Gateway IP address: 216.155.165.050
Secondary IP address: Blank
APN name: wap.voicestream.com
Data bearer: GPRS
Profile name: GPRS
Username: Blank
Bearer: Data
Home page: http://wap.myvoicestream.com
T-Mobile MMS Settings:
WAP Gateway IP Address: 216.155.165.050
APN Name: wap.voicestream.com
Homepage or MMSC URL: Messaging Server: http://mms.msg.eng.t-mobile.com/mms/wapenc
Data Mode: Connection Oriented
AT&T Browser/Java Settings:
Connection name: Internet GPRS
Data bearer: GPRS
Access point name: wap.cingular
User name:
Prompt password: No
Password:
Authentication: Normal or Secure
Gateway IP address: 66.209.11.61
Homepage: http://device.home
Connection security: Off
Session mode: Permanent
AT&T MMS settings:
Connection name: Multimedia
Data bearer: GPRS
User name:
Prompt password: No
Password:
Gateway IP: 66.209.11.61
Homepage or MMSC URL: http://mmsc.cingular.com
Connection Security: Off
Session Mode: Permanent
Apr 02, 2010 | Samsung Propel SGH-a767 Cell Phone
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Motorola w230 as modem (reliance sim card) number to dialed from pc and mobile settings pc username and password web session setting plese write soln if you have done by yourself
enter this settings on your cellphone
create a new profile
Reliance GSM GPRS Settings:
APN:rcomwap,
Proxy:10.239.22.305
Port:8080
Home:http://wap.rcom.co.in
For Reliance SMARTWAP:
Account name : SMARTWAP
Access point name: SMARTWAP
Home page: http://wap.rworld.co.in/gsm/index.wml
Wapgateway proxy IP address: 97.253.29.199
Port: 8080
For Reliance SMARTNET:
Account name: SMARTNET
Access point name: SMARTNET
Home page: http://www.google.co.in
Port: 8080
For Reliance MMS:
Account name: RTLMMS
Access point name:MMS
Homepage: http://10.114.0.5/mms/
Wapgateway IP: 10.114.0.13
Port: 9401
do the setting according to your plan
Dec 26, 2009 | Motorola Cell Phones
No access to set up modem or router
you might have configured your lan settings wrongly.
If your modem was setup for DHCP then you configure your lan to receive IP address automatically, DNS automatically.
If DHCP is disabled on the modem, you have to USE static IP Address for your lan ip and default gateway should be your modem default ip.
the default IP for modem is usually 192.168.1.1
if DHCP is disabled on the modem the sys ip is 192.168.1.3
So Configure your LAN setting as follow and Type http://192.168.1.1 in the address url.
Lan Settings:
IP Address: 192.168.1.3
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
click ok.
and type the above url, press enter the modem will ask you for username and password.
Good Luck.
Dec 27, 2007 | D-Link DSL 300G+ (DSL-300G+) Modem
Belkin (F5D5231-4) Router Logo
61 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
