Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
My whirlpool Quiet Partner 1 leaks from the bottom of the door.
  • 986 Answers
Some leaking around-under-from the door on dishwashers can be traced back to a split in the spray arm. If the lower spray arm develops a split in it, the spray arm can turn too fast, and shoot water directly at things that it is not suppose to spray water at....sprays water at the door vents or edges and can create water leaks. See if thats the problem
Posted on Nov 13, 2009
  • peter cranwell
    peter cranwell Mar 05, 2015
    Mine was dumping pools of water on the floor. Cleaning the crud from the inside of the screen fixed the problem Many thanks.
4 Suggested Answers
allbrands
  • 600 Answers
SOURCE: whirlpool quiet partner 2 Water
Hello, Thank You for using FixYa. I will be helping you today.There is no seal for the bottom it is an air gap. If there is a damaged lower spray arm or crack in it water will come over that edge. Check the spray arm for damage. Open the door remove the screws down the sides and remove the front cover the close the door and start a cycle then you can see better where the water is comming from
Thank You and please rate my answer if it was helpful..
Posted on Jun 24, 2011
SOURCE: Dishwasher (whirlpool quiet partner II)
I think I solved the door leaking problem by cleaning out the plastic filter screen on the inside (left) door panel. Didn't even know it was there, never knew it was suppose to be cleaned! It was so clogged and gross. I also discovered that my washer had shifted and was off balance. It has wood shims under the steel casing and one block was loose. No doubt from slamming and banging the door open and closed. Had to take the front skirt and kickplate off to see. I had my son use a lever and hoisted it up a little while I replaced the block shim now making the washer level again. Ran a light wash before fixing problems and it leaked. We ran a light wash after the fix's and so far so good. Haven't ran a regular longer wash yet. My water level was fine, no gasket problems, no washer wand cracks, etc... My husband was thrilled! When he came home, I informed him I have good news and not so good news. The not so good news was dinner was going to be late, the good news was I fixed the leaking (for months!)dishwasher and saved alot of money on repairs!
**Cleaned filter screen, made dishwasher level again.
Posted on Sep 09, 2008
ExHandyman
  • 86 Answers
SOURCE: WATER IS LEAKING OUT OF DISHWASHER DURING CYLE
could be one of 2 problems. 1) the rubber gasket seal has a small tear or hole... it doesn't take much. or 2) the door latch is loose or broken
Posted on Mar 13, 2010
HOW TO RESET MY DISHWASHER
All you can do is turn the power off at the power point, leave it for a few minutes and then switch the power back on.
Jan 11, 2016 | Dishwashers
Whirlpool Quiet partner V Dishwasher will not start no lights ,,,nothing
Try unlatched door and hit heated dry, normal, heated dry, normal all within 3 seconds of each ither. Close dior, latch and try again.
Mar 02, 2015 | Whirlpool Gold Series Quiet Partner Iv...
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Whirlpool quiet partner V leaks from bottom of unit
see the possibles causes; God bless you
see the diagram
May 16, 2012 | Whirlpool Washing Machines
Whirlpool quiet partner 2 Water leaks from the bottom of the door, alot of water, we can watch it pour out. The door is closed all the way. I dont see a gasket along the bottom of the door where it would...
Jun 24, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Mar 13, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool Gold Quiet Partner Dishwasher - Leaking!
Hello Summers2Go! We are terribly sorry to hear of your concern with your Whirlpool Dishwasher. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Summers2Go), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool 24 in. GU2500 XTP Built-in...
I have the Whirlpool Quiet (??) Partner II. My
Have this same problem with my Whirlpool DU1145XTBA. Found out that when you start the unit, it fills with water. If the water does not rise above the filter mesh in the bottom center of the unit then the pump doesn't have enough water to supply pressure to the upper sprayer. Had to replace the Flow Meter. It tells the unit how much water to supply to the unit.
Apr 12, 2009 | Dishwashers
Quiet partner 4 leaks water from the bottom of the door
Could be a seal issue. Make sure the D/W is level so that the door is closing properly and sealing ok. Too much soap will also make it leak. Replace the seal if it continues after those checks.
Apr 26, 2008 | Dishwashers
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
2,786 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
